  New Posts New Posts RSS Feed - full freq speakers
full freq speakers
raffe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote raffe Quote  Post ReplyReply Direct Link To This Post Topic: full freq speakers
    Posted: 23 June 2010 at 9:10am
hey im looking to build two full range speakers. i have a budget of about 600au dollars per speaker and think i will be running it off a crown xti 6000 amp. (1200w into 8ohm per channel) and suggestions or designs would be helpful. thanks.
Glenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenn Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2010 at 5:51pm
Single 15" woofer plus 2" throat (3"Voice coil) compression driver probably is the best bet for your budget. Use either the X15 plan on this site: http://www.speakerplans.com/index.php?id=x15, 18Sound plans http://www.eighteensound.com/staticContent/applications/kits/18Sound_kit15.pdf, B&C plans http://www.bcspeakers.com/suggested.php?id=0000000005, Beyma plans http://www.speakerstore.nl/constructions/77 but change the components to the following.
In Australia can be difficult to source good quality for decent price. Below is my suggestion
2" compression driver Celestion CD2-3065 ($500 pair)
The celestions are rebadged B&C DE85
Woofer
15CL76 B&C http://www.bcspeakers.com/PDF/PRD/15CL76.pdf is probably around $300ea
Though I only have last years price list and the above is a 2010 model.
This is from Acoustic technologies in Brisbane
Contact Ron Delbridge 07 3376-4122
Alternatively
If you can only afford a 1" horn driver, there is the Celestion CDX1-1745 (1746,1730 or 1731).
OR B&C DE250 $250ea from acoustic technologies
Edited by Glenn - 23 June 2010 at 6:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenn Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2010 at 5:59pm
The XTI6000 is slightly overkill for this job and you could probably save some money by looking at a QSC PLX1804 and put the left over money into the speakers or add subs.
PLX1804 $1299
Alternatively look into a smaller crown or the new EV amplifiers
Edited by Glenn - 23 June 2010 at 6:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote raffe Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2010 at 11:57am
thanks glen, definitely a big help :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenn Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2010 at 8:03pm
This place not too bad on QSC and Crown also
And this mob have refurbished EV P3000 and P2000 for $1500/1100
Edited by Glenn - 24 June 2010 at 8:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote raffe Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2010 at 5:58am
hey glen you seem to be a super whiz on everything and i realise i was being totally unrealistic trying to build a 1200w speaker for 600 dollars. so i was thinking i would stop being such a tight arse and build some mt122 with the p audio sn 12b neo and p audio sd 750n neo comp driver and p audio ph 2723 horn (total 700w). would i be able to build that so they are 4ohm and use the crown xti 2000 amp on 4ohm which will give me 800w. or would i have to just get a different amp not on the xti range?
and then i realised that if i want to build them the volume will totally drop off at at about 120-100 hz which is perfect for an x1 sub. which driver/amp would you recommend to run with this system. i recognise this system will be quite top end heavy but i think that will be alright for my use.
thanks heaps glenn, your definitely a huge huge help :)
colinmono View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colinmono Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2010 at 7:22am
Hi Raffe, welcome to speakerplans! Glenn's given you some good advice there.
There are a couple of problems with your X1 + MT122 idea:
- The X1 works best as part of a four way set up, with an upper bass cab above it (e.g. HD15, USB), then MT122 above.
- Two MT122 to one X1 will make for a very unbalanced system. Two MT122's would be more than enough top for four, six or possibly even eight subs. Have a look at this system.
- The MT122 has a reputation for being one of, if not the most, difficult plans on this site to build
If you'd like to build a sub plus a mid top cabinet system, I'd suggest going for a simpler reflex system, especially if its your first build. Think along the lines of X12 + G Sub (there are lots of possible variations though). Here's an example of this kind of system
Another (even better?) option would be to stick with your first idea of building a full range speaker. You can always add subs later. The plans Glenn suggested are good ones.
Edited by colinmono - 25 June 2010 at 7:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote raffe Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2010 at 12:03pm
hey thanks so much for the advise, im sure ill be fine with the woodwork component as iv done rather alot in the past and also im looking at making the mt122's as the start for a larger system, im just not able to afford it yet haha :). however i reviewed the curves of both the mt 122 and the x1 and have decided to replace that x1 with a g-sub and hopefully get some big sub-bass subs in there too :) once again thanks very much for all of your advise :)
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2010 at 7:22pm
Passive or active?
Surely active, so two amps?
Passive 1200w crossovers could be a litlle difficultConfused
It just is.
