G Sub and MT121 combo |
craig582
Joined: 06 January 2010 Location: Folkestone Status: Offline Points: 212 |
Topic: G Sub and MT121 comboPosted: 11 January 2012 at 11:06pm |
Hi guys, just woundering if 2 g subs and 2 mt121s would work together? also future plans to upgrade to 4 g subs and 4 mt121s? music is anything and everything from live to djs of all genres
cheers guys craig
Nitz V1505
Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1460 |
Posted: 12 January 2012 at 9:26am |
Looks like a good combo and will work fine crossed at 150hz. However certain genres of music that dj's play ( house/techno/garage for example) may require a kick/upper bass cab between the G's and MT's to sound really good. So if I was you when u upgrade have 4 G subs, 2 or 4 kick's and 2 MT's.
The MT's are very efficient so u can get away with a pair as I think with 4 u would need more sub. I think the reason why you could do with a upper bass cab is to reduce crossover distortion at around the 150hz mark and you can cross the MT's higher at around 180-200hz ,depending on your upper bass cab's , and cross the G's at around 80hz. hope this helps.
& THE TOPS LIKE LIGHTNING..... |
craig582
Posted: 12 January 2012 at 7:25pm |
cheers mate, what cabs would you suggest to use as kick above the gs? or should i just design som 15" reflex subs?
ta craig
Keen
Joined: 30 May 2011 Location: Brisbane, AUS Status: Offline Points: 402 |
Posted: 16 March 2012 at 12:53am |
For kicks above G-subs see:
ES18bph or USB kick bin or HD15 |
Meat
Joined: 05 June 2009 Location: France Status: Offline Points: 923 |
Posted: 16 March 2012 at 7:47am |
Just use bass drivers with light cones in the G-sub and you won't have problems or need extra cabs.
Tweet
