  New Posts New Posts RSS Feed - G Sub and MT121 combo
craig582 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig582 Quote  Post ReplyReply Direct Link To This Post Topic: G Sub and MT121 combo
    Posted: 11 January 2012 at 11:06pm
Hi guys, just woundering if 2 g subs and 2 mt121s would work together? also future plans to upgrade to 4 g subs and 4 mt121s? music is anything and everything from live to djs of all genres
cheers guys
craig
Nitz V1505 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2012 at 9:26am
Looks like a good combo and will work fine crossed at 150hz. However certain genres of music that dj's play ( house/techno/garage for example) may require a kick/upper bass cab between the G's and MT's to sound really good. So if I was you when u upgrade have 4 G subs, 2 or 4 kick's and 2 MT's.
The MT's are very efficient so u can get away with a pair as I think with 4 u would need more sub.
I think the reason why you could do with a upper bass cab is to reduce crossover distortion at around the 150hz mark and you can cross the MT's higher at around 180-200hz ,depending on your upper bass cab's , and cross the G's at around 80hz. hope this helps.Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig582 Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2012 at 7:25pm
cheers mate, what cabs would you suggest to use as kick above the gs? or should i just design som 15" reflex subs?
ta craig
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2012 at 12:53am
For kicks above G-subs see:
ES18bph or
USB kick bin or
HD15
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2012 at 7:47am
Just use bass drivers with light cones in the G-sub and you won't have problems or need extra cabs.
web department
