Garrard sp25's disco driver 80 |
Post Reply | Page 123 5> |
ollie80
Registered User Joined: 10 December 2012 Location: KENT Status: Offline Points: 117 |
Posted: 02 January 2013 at 10:06am |
Hi Chaps, HAPPY NEW YEAR. A question which ive been meaning to ask.. What was the difference between a Garrard SP25 and a Garrard SP25 disco driver 80? Im guessing they are both belt driven. Was the platter / motor more beefier in the disco driver 80? Im a right in saying the disco driver 80 is called an 80 because it was released 1979/80? Thanks!
Ollie K
Nothing is impossible, the word itself says 'I'm possible' |
jbl_man
Moderator Group Joined: 12 January 2005 Location: London. Status: Offline Points: 11154 |
Martin will probually know the definative answer to this.
The earlier SP25 MK 3 was idler wheel driven. (rumble city!) Both SP 25MK 4 and disco driver are belt driven. SP25 MK4 had a semi-auto function (arm took itself of record and back to arm rest after track finished,and switched off turntable,really annoying function,which i used to "disable" by removing the toothed gear wheel under the platter). Disco driver was completely manual.(no auto function) It also had a better arm if i remember. Citronic CL300 is better than both in my opinion,much superior "S" arm. |
ollie80
Hey JBL, thanks very much for reply.
I used to have two SP25 mk4 built into a custom console. One of the sp25s came from a dynatron music centre.. The other one was sourced from a single deck seperate. haha yes the semi auto function, even at a young age I used to place the stylus manually on the record! So I guess Garrard entered the disco market propery with the disco driver 80
Ollie K
Mhamplification
Young Croc Joined: 16 July 2009 Location: County Durham Status: Offline Points: 541 |
Yes Ian I know the answer to this one having piles of them around at the moment
SP25 Mk 3 idler drive semi auto deck SP25 MK 4 (IV) idler drive semi auto SP25 MK 5,6 were belt drive On deck fitted into disco console all the semi auto was diasbled normally by removing a cogged wheel under the platter the Disco driver was a purpose built deck for disco use Built by Garrard after BSR got in there first with the horrible plastic ones The Disco driver 80 came out in 1980 and was a stripped down version of the SP25 MK 6 No auto mechanism at all no controls only speed If you look at one the chassis is the same as a SP25 with plastic panels covering up the holes in the top panels My favorite deck was the DD80 although the cartridge sliders were a problem especially in hot swetty venues The DD80`s were labelled 36SB underneath i think The same turntable as a 35SB a more upmarket SP25 When I get 5 minutes I will do some pics of the difference between the SP25 mk 5,6 and Disco driver 80 /36SB |
ollie80
Hiya Martin!! Thanks so much for the answers you have given!!
Will love to see the pics too. Thanks a billion
Ollie K
Tony Wilkes
Still reckon that the MII was the best built of the lot.
mostyn
Registered User Joined: 24 March 2012 Location: cannock Status: Offline Points: 186 |
agreed tony screw off head shell first decks i ever had dark green in colour
mostyn
used to strip sp25's levers linkages etc so they worked like dd's
Mhamplification
The Garrard part number fro the Disco driver is 126SB not 36sb as I put earlier
mostyn
in fact i remember seeing some consoles of the time fitted with 126sb's,if i remember looked like a sp25 til you got closer then some subtle differences,the arm weight and a different silver t/table centre on the t/table mat,silly how some things stick in your mind
Mhamplification
that would have been a 125Sb they were very similar to the Sp25 mk 5 as you say the weight and the number near the start controls etc Ive got some Garrard catalogs somewhere will scan them when I can find the old scanner and post them up |
ollie80
Br great to see those catalogs! It funny, whilst growing up all the turntables I was exposed to were Garrard SP25s! My dads Dynatron music centre (MK4), my first FAL disco console (MKIIIs), and custom console MK4 from the Dynatron and another MK4 from a separtes deck
Ollie K
