  New Posts New Posts RSS Feed - Get you baby stacks out !!!
 Post Reply Post Reply Page  <1 56789 19>
simonh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonh Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2015 at 10:10pm
Logic X180's
Logic ML12's
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonh Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2015 at 10:30pm
B&C Sub18 - Fane Prime XS loaded
Opus MP400
michel29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michel29 Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2015 at 9:52pm
baby-stack ?
my firt DIY stack
Faital 18xl1600 for sub
JBL E120 and B&C de250 + RCF H100 for tops
sounds geat , i use it for live performances
the tops may be used as wedges
Edited by michel29 - 14 April 2015 at 9:53pm
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2015 at 10:57am
Liking the recessed speakon plate design for monitor duty, bit different.
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2015 at 12:11pm
Nice! Good to see someone else on the same page. I'll put up a piccy of mine soon.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2015 at 12:19pm
Originally posted by simonh simonh wrote:
Logic X180's
Logic ML12's
that's just nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michel29 Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2015 at 6:45pm
recessed speakon plate ?
i've made 4 boxes as same
2 for this stack
2 for a guitarist, he will use them as giutar monitor, fited with JBL E120
i've made 2 boxes in 2014 for monitor duty , with the same recessed speakon plate
a good protection for speakon plugs
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2015 at 7:35pm
my newly built MTH30 ( 3cm cut of the bottom so its a modded box... no reason, i just f**ked up reading the plans lol) with a void Mycro6 ontop. XT800 on tops and the pulse bridged on bass (PD12sb30) and yes i do like this colour scheme.
Edited by mini-mad - 18 April 2015 at 7:35pm
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2015 at 12:58am
Really keen to see measurements/opinions comparing it to the THAM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2015 at 1:17am
Cant measure.... i CAN give you my opinion though.
Let me get some time together and i'll sit in the garden and have them side by side and let you know their pros and cons.
As a 1st... the THAM does play lower and it would appear the the MTH kicks better. More on these two wen i have an hour or two free to have a little play. Also, this was my 1st time using tuff cab and i have to say i LOVE the stuff! Rolls on easy and washes out of rollers/brushs easily.
The one in my above post only has one coat at the moment.
The reason i built this one was because i wanted a little less sub and a little more kick as i dont want to shake all the glasses of the bar shelves. Its also a much bigger box too.
lost eden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost eden Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2015 at 5:05pm
I always assumed the MTH would play lower due to being a bigger cabinet, but then I guess it isn't always that straightforward a relationship. Still jealous of those Myrcos, they were always my first choice before I settled for the 8" tops I eventually got!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2015 at 5:41pm
Just looking through this thread and I do wonder what exactly qualifies as a 'Baby Stack'? There seems to be some fairly large boxes here, so maybe we should restrict this to stuff smaller than, say 12" drivers and/or a couple of hundred watts?
Anyway, my contribution is something I just knocked up to go with my new laptop. 2 x 5.25" whizzer speakers and a small amp based on a couple of TDA2030´s.
Both vertical:
Or horizontal stacking:
And yes - it made from an old draw. Sounds damned good tho´.   LOL
This page was generated in 2.203 seconds.
