Get your Racks out.... |
Post Reply | Page <1 142143144145146 165> |
discosucks
Old Croc Joined: 06 November 2009 Status: Offline Points: 1548 |
ohh boy!!
Earplug
Nice work. Aren´t those little (Chinese) meters great. It would have cost a small fortune to to the same metering a few years ago.
Shaun
Registered User Joined: 03 November 2013 Location: South Wales Status: Offline Points: 285 |
No, it is not a line array it is some well stacked boxes...............
lost eden
Young Croc Joined: 04 April 2011 Location: Dundee Status: Offline Points: 942 |
Glad you used a shock mounted rack
Shaun
SMP
Young Croc Joined: 16 March 2013 Location: East London Status: Offline Points: 1226 |
I have a Rack to build for an Install this Week. NOT a Task I like at all. I wish, there was someone else, to do it.
Earplug
Yes, one I bought also had that. Have a look at the board - there should be a couple of adjustable pots in there. One controls the voltage reading, the other the amperage. Adjust to suit! |
SMP
@ Earplug
Yes, one I bought also had that. Have a look at the board - there should be a couple of adjustable pots in there. One controls the voltage reading, the other the amperage. Adjust to suit! ??? For Real??? |
AJordan
Young Croc Joined: 06 July 2007 Status: Offline Points: 1013 |
Calibration - for those places where the volts and amps are a little different to regular volts and amps
lost eden
Thanks(1)
It's so when the load increases & the voltage drops you can just tweak it back up to 240v, yeah?
AudioSystemsEngineer
Registered User Joined: 11 November 2013 Location: London Status: Offline Points: 144 |
decent switching amps will regulate their power supplies ;-)
Earplug
Ok, maybe I didn´t put that clearly enough - and obviously humour isn´t your thing... These are cheap units, obviously shunted out the factory by the hundreds without too much QC, so the calibration might be a bit off when they arrive. A simple matter to check against a (proper) multimeter and adjust so that they give an accurate reading. Once set, they seem to hold ok - I haven´t noticed any drift or strange behaviour from those I´ve got here. Edited by Earplug - 25 November 2014 at 10:38am |
