TSW-718 vs USB Sub |
Post Reply | Page <1 234 |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
154 & 1550 will hit you too hard I think.
I'm really happy about the mb15n401, but some of their smaller coil drivers might also be good. People often talk about small coil being important, looking at the tsw-21 this seems like nonsense, 6" coil heavy cone playing up to 150hz!! fane studio 15b sounds nice in there, but also I think colossus 15b or 154 should work ok in big groups, aren't they less honky in stacks of 6? If you want to try that martin I'll give it to you for £50, it's almost like mint condition! Go listen to some straight kick horns Do it:-) |
DMorison
Generic name for a type of common household cleaning cloth - very light fabric so won't add excess weight to the driver but absorbent so helps retain the adhesive. Also, extremely cheap and very readily available.
mikelink
Registered User Joined: 21 November 2012 Status: Offline Points: 63 |
i have 15nd930 16ohm inside 4 tse215 and they sound good, also they are the 16ohm version so i can power 4 cabs with an ampli
tv00
That sounds like a good choice! Also used in xtro.
Should have light cone & strong motor as I recall. Not a cheap solution Let me know if you ever need RC-kits, I have 9 of these on the shelf! Also let me know if you stumble upon some blown drivers of these! |
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 563 |
Edited by RoadRunnersDust - 11 June 2019 at 3:28am |
