Another 15" BPH |
Post Reply | Page <123 |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Thanks(1)
Try rcf mb15n401 or 351 for reaching the highest freqs, light cones
Try the lf15x401 for maximum bass, last one might not fit due to magnet size, then try n451 |
Kingjoonathan
Registered User Joined: 18 October 2012 Location: Finland Status: Offline Points: 38 |
Too high prices on those drivers. what about PD 156? Should be very nice for hd15. This is quite close to hd, and if I make the cab 500mm wide it should work, right? Would feed it something around 500w max so it wouldn't rip the cab in pieces.
What do you think, corell and tv00? Edited by Kingjoonathan - 26 January 2015 at 11:42am |
SALAMARI SOUNDSYSTEM - FINLAND
tv00
Yes you are, PD or RCF, no difference in EU.
Bluearan stock both Teamaudio is cheaper with rcf / b&c (at least outside UK) Bluearan is cheaper with pd / fane, check also mlc audio. Loads of other suppliers too! PD.154 is the suggested driver for HD15 PD.156 is not well suited, don't cross above 180 hz using hd15s |
corell
Young Croc Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1161 |
kappa 15 lf was one of the chassis i suggested and if budget is an issue, i would go for the thomann 15lb100, as it is really close to the kappa, maybe even a little bit better.
tv00
Ah, we're talking budget, that's cheap for a decent looking driver, specs?
@ Kingjoonathan : Thomann should ship to you too, all european shops will for sure! |
corell
all specs of the 15lb100 on the thomann site, xmax is 5,5mm.
kr1sounds
Young Croc Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
anyone built this yet?
fostonshfs.webs.com |
