Bluetooth + FM input options |
Post Reply | Page <123 |
Eggie
Registered User Joined: 06 March 2010 Status: Offline Points: 76 |
Hi Bitshamsher, Wth Regards to the Module your buying there, ive just bought something similar of ebay. Does you or anybody know where can get the Connection plugs from as both my Amp and MP3 module wernt supplied with um. Need a two 3 pin females both ends and one 2 pin female. Cheers
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
6 weeks later... modules arrived!
Haven't had time to play with them, but I was planning to solder my connections to the pcb That's the easy part, getting a 12v to3.7v step down won't be fun Another 6 weeks perhaps |
microbug
New Member Joined: 24 April 2014 Location: England Status: Offline Points: 3 |
You need a LM2596 board from eBay. They are adjustable step-down (buck) converters, which by their nature are fairly efficient. Connect the input to your power supply (battery) and the output to your multimeter and turn the screw on the potentiometer (little blue box on the board, the screw is a golden colour) until the voltage reads 3.7V. Then connect the output to your module and it should work.
These LM2596 boards can be bought from China, but if you don't want to wait you can get them for AU$ 5 on eBay (I checked). Sorry for the late reply...
bitSmasher
awesome, thanks for the reply! found someone nearby selling 4 for $11AUD, that works for me...
