  New Posts New Posts RSS Feed - post-charge voltage of SLA batteries
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Topic: post-charge voltage of SLA batteries
    Posted: 19 March 2014 at 10:38am
For the folk using 12V SLAs ....
Just wondering what voltage people are seeing after their normal charge cycle.
I have several SLAs :_
1 x 7Ah Ritar bought new last year - always charged soon after use and gets maintenance charge every few weeks during winter.
13.19V
1 x 7Ah Powersonic I got given - unused at the time, but likely had sat on a shelf for some months without maintenance charge.
13.00V
1 x 7Ah Yucel that I bought new 4 years ago - not so well maintained - still works ....
12.10V
2 x Yuasa 24Ah mobility-scooter type .... 1 was unused, 1 used - both had a few months without maintenance charge before I was given em.
12.76V and 12.73V respectively
1 x 24Ah Ritar bought unused but prob not maintained for some months before it came to me (fitted to a jump-start case) - lightly used - always maintained.
13.02V
These days I use a Lidl £12.99 smart charger for all the above - set to charge at 14.4V (it also has a 14.7V setting).
These voltages are measured with a cheapie little digital meter about 10-20 mins after charge has completed.
What do other folk see ? ... and please indicate what kind of charger/regime do you use ?
Reason for asking is - I wonder to what extent the post-charge voltage indicates the real-world battery condition.
Edited by slaz - 19 March 2014 at 11:11am
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2014 at 1:55pm
A fully charged 6 cell lead-acid battery in good condition should read about 13 - 13.2v immediately after charge and for some time if nothing is connected, and should drop to 12.8v under moderate load. I usually assume the range from charged to discharged is 1 volt, from 12.8v down to 11.8v, with each 0.1v drop representing 10% capacity used. I try not to go below 12.0v in normal use though.
That Yucel 7Ah definitely has a problem, and should read higher than that. I bet if you put a load on it like a 12 ohm power resistor (for a 1A current) it drops right down to about 11.0v, yes?
According to some fearless geeks wearing rubber gloves on Youtube, it is possible to top up even a gel battery with distilled water, and sometimes this recovers lost capacity. It might also be worth trying a desulphation device to clean the plates.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2014 at 4:21pm
Most of my 12v batteries read 13.4 to 13.6v after charge. In use they hold steady at 13.2-4 until they drop to 12.8 after an hour, and then stay there and gradually go down to 11v when fully discharged about 8-24hr hours later. Bearing in mind they are 120ah deep cycle running bigger systems.
