Why do reggae sounds use scoops? |
Matt Lebowski
New Member Joined: 15 April 2014 Location: Gloucester Status: Offline Points: 9 |
Posted: 20 April 2014 at 2:26pm |
Hi,
I am wondering why so many people are using scoops for their low end. I have seen countless frequency response graphs for scoops, and they all have a very uneven response across the spectrum. It's like a comb filter sort of thing.. Practically every Reggae/Dub sound system use scoops and I can't work out why considering the FR of that particular design. Surely you would want a speaker with a flatter response? Or is it that they are good at covering a narrow band at a higher SPL and are used with other subs to compensate for the other frequencies? Pretty new to all this, but have been doing a lot of research so please forgive if my terminology is slightly off track.. Thanks! |
King Simeon
Young Croc Joined: 13 January 2007 Location: United Kingdom Status: Offline Points: 788 |
Reggae sounds don't follow any book and freq studying as a tradition. Personally a flat response is a basic start point, but not a characteristic. Different music genres have their own traditions and characteristics.
It's a topic that has filled a few pages on this forum. Some sounds have used some study and testing to get more out of their sounds, many still use scoops. It's not what you read, it's what you hear is also a big point. It's a specific type of bass that scoops give that reggae sound mostly want.
https://www.facebook.com/KingSimeonSound?ref=stream
https://soundcloud.com/king-simeon |
Selector Waxx
Registered User Joined: 08 April 2014 Location: Gent, Belgium Status: Offline Points: 31 |
Scoops is a combination of frontloaded and horn speaker, wich causes phase issues as the vibrations from the front and from the horn (comming from the back of the driver) don't travel the same distance to your ears. This gives a chorus like effect wich creates a warmer bass sound.
Strictly front loaded or horn loaded or bandpass speakers don't have this issue/feature... Edited by Selector Waxx - 23 April 2014 at 1:56pm |
supapowa
Registered User Joined: 15 January 2008 Status: Offline Points: 74 |
Efficiency + most like how scoops play.
Jhodas
Young Croc Joined: 04 June 2007 Location: United Kingdom Status: Offline Points: 1244 |
Uneven driver loading + phase strangeness = distortion harmonics.
Most of which sit around the resonant frequency of the human chest cavity. Result: Bass that shoves you around. *this may or may not be a load of bovine excrement.
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
Scoops are highly efficient bass horns that give some degree of gain when used in their frequency range, any dips or peaks in response tend to be outside the intended range.
I would say one scoop in hand is worth two reflex in the bush. |
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
yes 1 15" scoop is worth 2 18"reflex in the bush |
TONY.A.S.S.
It would also seem like the Scoop is a cab where many people can put their own stamp on it. Most times I only hear Sound effects from them, usually from the misuse of the equipment, which is why there is a big re-cone business within the Scoop community.
burningbush
I'll get you coat Tony, taxis here.
