Moving Head Orientation |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8707 |
Posted: 11 August 2014 at 3:42am |
So with moving heads, I know it's safe to use them upright or upside down. But how about on their sides?
The heads are Pilot 150s |
Jimmer
Old Croc Joined: 30 April 2010 Location: Stroud / Glos Status: Offline Points: 2604 |
The futurelight heads I havr just picked up state they can be mounted sideways.... Def check the manual, but should be ok I'd have thought.
Light travels faster than sound....That's why some people appear bright until you hear them speak!
AM55
Old Croc Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1728 |
I once read someone say if you mount a scanner upside down you will invalidate the warranty, .
Mount them any way you want, they'll be fine. |
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
Some arc lamps will have reduced life and poorer output in certain orientations but as the lamp in a moving head is constantly changing orientation this cannot be avoided.
I always prefer to hang things under their clamps (if it will make no difference to the lighting design) - no point fighting with gravity more than you have to. |
jacethebase
Old Croc Joined: 23 September 2009 Location: Somerset Status: Offline Points: 5697 |
Use decent half couplers you will be fine. A pilot 150 is not a very heavy unit anyway.
Jace |
www.stage2sound.com |
SamV
That's what worries me lol, maybe it wasn't built to take the same strains as say a Robe or Martin head. But then I know little of how it's built. |
SamV
That's what worries me lol, maybe it wasn't built to take the same strains as say a Robe or Martin head. But then I know little of how it's built. My worry wasn't about it falling but more about it damaging itself due to being unbalanced on one axis? |
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
The HTI 150 lamp used in the Pilot 150 has a burn position code of HS30, this means the arc has to be kept within 30° of horizontal, if the fixture is mounted on its side the arc would not kept horizontal. |
JohnnyPyro
Old Croc Joined: 17 November 2008 Location: London Status: Offline Points: 2083 |
I wouldnt worry about the lamp
Id be more concerned about the central pan bearing, they're not the best and seen quite a few collapse when mounted sideways, you are adding sideways shear to the bearings when mounted like that |
Powered by MC2 & XTA |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
Isn't that a disadvantage for a moving head? Im dure I've seen them mounted on circular truss on the PR plasa stand Edited by kedwardsleisure - 11 September 2014 at 10:06pm |
North Staffordshire |
