help.. please!! |
Post Reply | Page <12 |
kr1sounds
Young Croc Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
cheers lev, have you heard this cab play before by chance?
fostonshfs.webs.com |
T-Bone
Registered User Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 292 |
Nice Turbo plans is there another driver like Eminence Kappa 15 LF sound good on these like the HD15's? Curious if any other 15" will work that's available here in the US? Thanks Guys!
BASS, how low can you go!
djeddie
The F2B will easily reach 250Hz, if not higher... it's just you'll never see the plans. They're not on the 'net. |
siox
Registered User Joined: 26 January 2010 Location: Austria Status: Offline Points: 34 |
yes they are rated up to 250hz, it will just sound more "clear" if you cross them at 200 or 220hz.
they need some eq - but with the correct settings they are the best sounding kick filler i know. regards, george
Edited by siox - 06 September 2014 at 10:23am |
levyte357-
HD15 is cut down version of turbo box. Cut down in size & freq response. Have heard these BPH 238 (Basically TSE115), but was not with optimal driver, or LMS handling delays/response smoothing. However with correct setup, would expect these to eat HD15, with same driver/amplifier. Edited by levyte357- - 06 September 2014 at 10:50am |
