2/18 port ? |
Post Reply | Page <12 |
patryk1305
Registered User Joined: 13 December 2012 Location: United Kingdom Status: Offline Points: 488 |
sn95
Registered User Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
Ok after reset the inputs to max I got a peak of 24.5 m/s at 30 hz
DMorison
Seems more realistic, and pretty reasonable too. Take it they're quite low powered drivers?
sn95
1000 rms
rffrecords
Registered User Joined: 06 February 2010 Location: Greece Status: Offline Points: 91 |
For sure you have got it wrong.
There is absolutely no twin 18" that will take 1000+1000=2000 watts on 3 tiny 4" ports on this planet. Don't be shy. Just name the 18" you are trying to build a box for. If it is of any use as a subwoofer, I will suggest you a design. Edited by rffrecords - 14 September 2014 at 11:38pm |
patryk1305
He is trying to expand on the G-sub using the Dayton PA465S drivers. He has increased the port size so it's all good now
Edited by patryk1305 - 14 September 2014 at 11:50pm |
sn95
no top secrets hereit's my take on a G SUB and as Partyk pointed it out I will be using the Dayton PA465 .I have change the enclosure volume and port size to suit the driver.as for the ports being aroundit is my understanding that it's a more efficient design.
sn95
Big thanks to speaker plan,and the ported box enclosure segment of the form,finally got the box is built and tested sound good.and the Finnish isn't too bad,you will be using them outdoors for the first time on Saturday.BTW I wish I could post pictures but it doesnt let me upload .
patryk1305
Good to hear
You can upload photos to an image hosting website like imageshack and then link the album to here
Alternatively try reducing the size of the photos and see if that works |
