HD15 Controller setup |
janovic_x
Registered User Joined: 27 November 2012 Status: Offline Points: 80 |
Posted: 28 October 2014 at 6:11pm |
hello!
got some small problems with my hd215. now repaired everything. just want some opinions about my controller setup. 2 Stacks of 6 HD15 or one stack with 12 HD15, but most of the time 2 stacks. chassis is oberton 15b450 (450w rms) (see google). amplifier is about 3600watt each stack (2700watt rms). Running them from 44 Hz (24db Butterworth) to 151 Hz (18dB Butterworth). Low Cut set by the Equalizer 25Hz. Is that working? Especially want to know if the chassis is getting cooled by this setup enough? I mean, moving of the membrane.. Thanks for your help. |
njw
Looks ok to me, I ran my HDs 45-150 and they sounded great. Each cab should be getting around 600w which for a 450w driver shouldn't be an issue at all as long as you're not doing anything daft.
janovic_x
which filter you use at 45 hz?
bass*en*mass
running these cabs at 1200W per bin should not be an issue, limiter set to avoid the Amps clipping, Butterworth 18-48 HPF at 40-45,depending on sub content, volume and taste, LPF suitable to your Tops, 155hz sounds quite honky tbh., some EQ might cure that issue, depends a lot on styles played and the Tops :)
are you using dynacord`ish tops btw? ;) The Limmer doubles showed no signs of stress cutted even lower + EQ down low to sound more balanced on their own.. (thats 4 a side in a small venue, hpf only starts to get important if the levels are up to the limit of the cabs/drivers limitations) |
njw
24db butterworth, same as yourself! I also ran 24db butterworth at 150, there was nothing scientific about it, I played with a few different slopes and that's what sounded best to my ears.
janovic_x
Sounds brilliant again... Edited by janovic_x - 03 November 2014 at 8:06pm |
all bass
PA horns for hf?
janovic_x
no, just decoration ;) they are from a trainstation...
