  New Posts New Posts RSS Feed - SR707 & SR404 Gain
SR707 & SR404 Gain
charlynch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlynch Quote  Post ReplyReply Direct Link To This Post Topic: SR707 & SR404 Gain
    Posted: 10 November 2014 at 7:56pm
Hi,
Could someone please let me know the amplifier gain for C-Audio SR707 & SR404, I have spent ages trawling the web to no avail.
Cheers.
boominbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boominbob Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2014 at 4:01pm
This is all the info i have:
sr404 2x466w / 4
sr606 2x625w / 4
sr707 2x826w / 4
Grubbah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grubbah Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2014 at 4:13pm
Originally posted by charlynch charlynch wrote:
Hi,
Cheers.
Do you know the power and input sensitivity?
simonp1100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2014 at 7:49pm
Input Impedance = 10K.
Sensitivity = +4db.
This applies to all ranges of SR amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlynch Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2014 at 4:49pm
Thanks for the help guys, would that make the amplifier gain 33.40 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2014 at 6:26pm
Hi, I am sure the gain works out at about 47 if my memory is correct.
Edited by simonp1100 - 26 November 2014 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grubbah Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2014 at 8:48pm
Simon is that +4dBU? (1.2V)
That would make the voltage gain around 34 no?
Post Options Post Options   Thanks (0) Thanks(0)   Quote simonp1100 Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2014 at 9:19pm
Looking at the circuit, the two feedback resistors for each channel are 47k & 1k, which sets the gain at 47 (approx). The spec says it's +4db (1.23 volts), so i assume there may be a small amount of tolerence.
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlynch Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2014 at 4:00pm
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grubbah Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2014 at 3:37pm
I get you
33.4db * 47...
Edited by Grubbah - 29 November 2014 at 4:23pm
