Solar Charge Controller |
immortal
Registered User Joined: 07 January 2013 Location: Sheffield Status: Offline Points: 460 |
Posted: 04 December 2014 at 4:18pm |
I have a solar charge controller, I have tried charging up two 7Ah wired in parallel sla batteries with a 12v 1A dc power source however it doesn't seem to work.
I read that you need approximately 16v going into the controller to charge the batteries because that's how much a solar panel would output. I have a 12v adjustable step up transformer, would it be a good idea to set that to 16v then have that between the psu and the controller? I don't know if the psu has any current limiting, could the controller could just pull the peak output from the psu and potentially run hot/set on fire? cheers
Cemetery Sounds
Earplug
Depends on the controller. Most will have some sort of current limiting. You definitely need more voltage to get it to work. Maybe try it out with a 1A fuse in series and see what happens.
Phil B
Old Croc Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2328 |
Is it an MPPT solar charge controller??
.p.
Hemisphere
How many Watts is your panel and how long did you try to charge it for? It's not been all too sunny lately I noticed.
Phil B
Don`t think there`s a panel involved. Is this what your doing? Mains 240v AC- 12v DC PSU -> Solar Charge Controller -> Batts Not really ideal? Are you just trying to maintain the batteries? If so maybe get a cheap 240v motorcycle trickle charger and sack off the solar charge controller? .p. |
amlu
Young Croc Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
on last going out with the rig i wired my panels directly into the batteries, with schottky diodes in series for reverse current and it work, 11v on the battery nicely stabilized whatever was coming out the panels.
only experimenting i was not worried about overcharging. for controller - anything above 13 volt should give you some charge for 12v battery . if not get another controller, preferably with voltage and current display... |
kingkwak
Young Croc Joined: 08 October 2010 Location: sussex Status: Offline Points: 810 |
Are the batteries suited to trickle charge? Or are they motorcycle batteries? If they are for the use you are intending then they should have a float charge rating (14.8vdc) and number of charge cycles. If you are local to Crawley in Sussex then I have a case and charger that will suit you. Free on collection.
To much power? NEVER.
immortal
It is a MPPT solar charge controller. Its in a portable speaker I made, so to charge it up you can just plug a kettle lead in and it will recharge the battery without having to take them out and connect them to a charger. They are these batteries: |
Cemetery Sounds
