Stereo Tweeters and single Woofer. |
Shortrope
Posted: 08 December 2014 at 6:24pm |
This is probably a dumbass question but here goes...
Would this work? One 2 channel Amp (Maxamp or similar), two crossovers, two tweeters and one Bass driver. Tweeters in stereo and Both low outputs from the Crossovers into one Bass driver. |
mk2_ginger_biscuit69
yes and no.....
get a double voicecoil bass cone, allows you to run a left signal through one coil and a right signal through the other coil - very similar to how many commercial small rigs were configured in the 90's when amps were more expensive.... It works, but isn't really ideal - sometimes panning in the bass range can create +-6db cuts/gains to the bass where the two channels don't sum well [quite rare i've come across this issue though]. Ideal for super simple compact rigs, albeit id rather just get a 4channel DSP onboard amp, with stereo tops, and two channels bridged into a single sub. Sorted. |
Shortrope
Thanks for that Ginger.
I've a pair of Tannoys, one with a bust woofer. I was thinking of making a 12v Boombox with them. |
well yeah, essentially your stereo amp signal would go into the sub, which would contain your two passive crossovers.....
they will feed a coil each, and the high can go out on two speaker outs. Ideal solution when things need to be kept simple - perfect for 12v boombox etc etc.... |
