Help Needed For An Upgrade |
Author | |||||||||
kr1sounds
Young Croc Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
Posted: 19 January 2015 at 6:48pm |
I have an old Dell Latitude 110L that i want to run music recording and dj software i dont know what the current specs of the laptop are like RAM and processor but it needs to be upgraded.
Heres the specs needed for the dj software
Does anyone know where i can get these parts? cheers
fostonshfs.webs.com |
kr1sounds
found the laptop specs http://www.dell.com/downloads/global/products/latit/en/spec_latit_110L_en.pdf
kr1sounds
i also am going to put windows 7 on it if possible
shagnasty
You are kinda screwed, the Lappy you have has a max 1.6Ghz CPU which will be 32bit only.
Crucial show a max ram load of 1Gb so you can't even get near the min spec for you software, add the that what I am sure will be a hideously slow hard drive, (based on the max 60GB spec I am not think SSD here) I think you could spend £27 on a module to bring the ram to max and still find your CPU can't cope. A single core/single thread 1.6Ghz isn't a 2GHz C2Duo by any stretch and for audio work, I would be think not at the min spec, more a 2.5 Quadcore and 6-8GB on win 64.. For the cost of the ram it may be worth a punt, but TBH, here http://www.cpu-world.com/Compare/241/Intel_Core_2_Duo_Mobile_T7200_(Socket_M)_vs_Intel_Pentium_M_1.7_GHz_(RH80535GC0291M).html shows your prob.... |
odc04r
Indeed, flogging a dead horse with that one sorry to say. It will do music recording with ease but you may be out of luck with DJ software.
kr1sounds
a new laptop it is then
SparkzDesigns
Registered User Joined: 06 February 2015 Location: Luton Status: Offline Points: 38 |
Hi there, iv built around 10 PC's so far and i buy all my parts from either RL Supplies Watford (they Deliver) or Eclipse Computers Coventry ( They Deliver)
Kind Regards William
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
I buy my pies from JG Ross. Fine.
Tired and horny, of Andover. |
MattStolton
Horny? - no excuse to be in (a) Ewe. Trust your wearing your wellies (as in "Bread", not how the welsh wear wellies, around sheep). Carry on.
