  New Posts New Posts RSS Feed - UK Box Builder - PCH Audio
 Post Reply Post Reply Page  <1 234
Audio_Stash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio_Stash Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 1:19am
No they are just there for show, I don't use them.
I just hold panels in place with my teeth whilst fixing in position with a sledge hammer and roofing nails
Edited by Audio_Stash - 05 May 2015 at 1:31am
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 1:33am
A good machinist won't need clamps. I only ever had two max, and they rarley got used
You are a good cab builder, no doubt. Finishing needs some work as i can see, in some close up shots.
If i were you i would stick with current free designs and build up a name for yourself. Less than 1% of builders will make enough money to pay bills and live off the earnings
Don't try to come up with designs/experiment, then sell that work, you will end up getting a bad name. Try not to give advice on here if you can't back the advice up
Good luck
Mykey Wattco
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2015 at 9:22am
Very good advice mykey. The same advice I've given Joe.
This page was generated in 2.859 seconds.
