Crossover phase help |
Post Reply | Page <123 |
kr1sounds
Young Croc Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
I'm doing one for my system and i know my crossover points. Used the same ones for years
fostonshfs.webs.com |
RobinMatrix
Young Croc Joined: 23 August 2013 Location: Kidderminster Status: Offline Points: 567 |
Yep, I am sure you do.
I was not talking about crossover points, I was commenting on adding all-pass filters to linearise the phase response ... its the phase response of the xover+driver you have to correct, not the xover alone. |
Matrix Pro Audio ::http://matrixproaudio.com/"
kr1sounds
Oh, ok i get you. Dont know much on all pass filters, where would they go in the circuit?
audiomik
Old Croc Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2962 |
All-pass filters can in theory be inserted into any or all of the Xover bands.
However usually at the outputs so as to compensate also for component tolerance variations and others such as individual speakers, etc, to a greater extent. Makes a big difference to the transient performance of a system when properly set up. Have a look here: http://www.edn.com/electronics-blogs/living-analog/4375814/All-pass-filter-phase-shifter Not the only web-page on this by a long way..... but does cover the 'basics' and some of the design maths.... together with basic cascading of them Mik Edited by audiomik - 03 May 2015 at 6:41am |
Warning! May contain Nuts
plus springs, washers, screws, etc, etc. |
odc04r
Use anything for now just to get it working. When that works you want to use a universal op-amp and then obtain a SPICE model for an OPA2134. Make the universal opamp use the SPICE model (pretty easy). |
fatfreddiescat
+1 and then some
Just to add, it's good to see someone having a go at designing their own filter but as mentioned it is the sum of the system that is important, if your loudspeakers are aligned 'acoustically' and the frequency response is flat for approx an octave either side of the xover point then it should work ok but anything less and you may want to measure the response of the complete system as you go. etc
Edited by fatfreddiescat - 04 May 2015 at 12:05am |
kr1sounds
i'm thinking of using a 12 db/octave filter with an all pass filter to make sure the phase is correct. is this worth doing?
Earplug
The filter really needs to be 'tuned' to each particular system you´re using, so it´s a bit more complicated than just chucking in an all pass. You need to analyse the whole system with something like SMAART and tweak the phase then. I think you´re overcomplicating the whole thing, really.
odc04r
+1. Stick to simulating and designing your basic 3 way. If you haven't managed to sim that successfully then there's no point in adding more complications to your life that you can't predict either.
You probably do not need an allpass, and you won't know for sure until you've measured the total system response. For now just ensure that your crossover outputs are in phase with each other and go from there. |
