Powersoft Max Voltage Attenuation? |
Grubbah
Old Croc Joined: 14 July 2011 Location: Portsmouth Status: Offline Points: 2004 |
Posted: 31 July 2015 at 9:27pm |
Trying to figure out what peak voltage I want to set corresponding to the peak wattage I want to pull out the amp?
Can anyone send me in the right direction of a decent conversion table?
Edited by Grubbah - 01 August 2015 at 12:09am |
csg
Look up ohms law, or use one of the free converter apps available.
Grubbah
Bit of a silly question really!
Thanks
Edited by Grubbah - 01 August 2015 at 3:55am |
Bryan M
Old Croc Joined: 17 July 2004 Location: England/Belgium Status: Offline Points: 2223 |
Hi Grubbah,
Is this for setting the limiters in the DSP amplifiers? B
merc 313
Registered User Joined: 02 August 2009 Status: Offline Points: 84 |
bass*en*mass
was wondering too how the powersofts handle their options to limit output voltage vs. mains current from a sonical point of view..
if i set voltage to highest possible but limit mains to min of 15A, fast, to draw the least possible, what does actually happen to the signal if the amp exceeds the current draw/limits itself? having played same subs+amps running off 16A and 32A leads me to the conclusion that the k10s indeed tends to reduce lf response in favour of keeping levels unnoticably changed. (loosing sub notes if current is limited, other than that still high output) |
