10 inch scoop, any driver? |
Post Reply | Page <12 |
Sheggy
Old Croc Joined: 23 May 2008 Location: London Status: Offline Points: 1991 |
For home hifi I would investigate transmission line and tapped horn designs if you want the bass response of a full scoop. Just my opinion of course.
italgil
Registered User Joined: 21 September 2011 Location: Portugal Status: Offline Points: 21 |
The back loaded horn are speaker boxes that atract me.
For home i shall look for other design Now this box might use for high bass on small p.a. |
all bass
Backloaded horns aren't the best for upper bass because of the huge dip where the direct radiating driver and the horn part are 180 degrees out of phase. So to overcome this you will have to cross above or below this frequency.
That's why most people use upper bass cabinets over scoops. |
italgil
How can i measure that frequency? |
all bass
With a measurement mic,external soundcard, a program like REW or ARTA.
You could also simulate your cabinet + driver in Hornresp and see the response there if you have no measurement equipment.(would have been smart to do before starting construction anyways) But measuring is the best way forward now. |
