Crossover Guru's I Need Help |
only126db
Registered User Joined: 15 December 2009 Status: Offline Points: 16 |
Posted: 30 August 2015 at 3:04am |
I picked up a pair or Mirage OM-9's for one heck of a deal but one of the High frequency channels does not work.
I pulled and metered the drivers and they checked out, and the Wire to the crossovers checked out. I believe I narrowed it down to this component which I believe is a Metallized Polyester Film Capacitor rated at 1uF/5%/100V. Problem is I cannot find a replacement that doesnt have some other letters like CBB, CBB2 or is not the same size. I was told I could replace it with a regular Metallized Polypropylene Cap (Parts Express said so) like the Solen or Dayton Caps. I am confused though because on the crossovers there are other 'normal' caps too and they did this for a reason and I am afraid the change may negatively alter the sound characteristics. So my questions are.... #1 is this a Metallized Polyester Film Capacitor #2 is it rated at 1uF/5%/100V #3 can I replace it with a Metalized Polypropylene Foil Crossover Capacitor (will replace other one in other crossover too) #4 what do you think will happen with sound Also here are pics of said component and crossover |
all bass
If you change it to an appropriate cap with the same values then the sound won't change at all.
Except when you are an audiophyle, then you will hear a difference if the cap hasn't been made from snail bones and the powercord is not made of braided angel pubes... |
only126db
I just ordered two new caps... Just bought some Bennics, had good luck with them before. THX |
only126db
Was Craigslisting, saw some tower speakers for $30, emailed to
inquire the brand even though by the shape I had a good idea what brand
they were.
The seller replied with something close to the brand name with an appropriate model number (figured they couldnt read the brand name in script on grill). Went and checked them out the next day and it seems a relative who used to live there took off across the country and left a bunch of stuff so they were either going to sell them or trash them. One speaker had an issue so I offered them $10 and they agreed. I traced the issue to a bad capacitor on the crossover, replaced it, painted them and...... For a total of around $30 here is what I got. Specifications: Drivers: Two 1" Titanium Dome Tweeters, Two 6 1/2" Polypropylene Woofers; Ported MFR: 38 Hz - 20 kHz ± 3 dB Nominal Impedance: 8 Ohms Crossover Frequency: 1.9 kHz Efficiency: 90 dB Power Handling: 150 Watts Size: 43 3/4" H x 11 9/16" W x 12 3/4" D Weight: 45 Pounds Each Finish: Cherry Wood or High Gloss Black MSRP: $1,400/Pair for Gloss Black |
