Battery Powered 3-way Horn Loaded PA |
Author | |||
ungelovene
New Member Joined: 17 April 2016 Status: Offline Points: 2 |
Posted: 17 April 2016 at 10:53am |
Edited by ungelovene - 17 April 2016 at 10:53am |
Twintub
Registered User Joined: 24 April 2016 Status: Offline Points: 12 |
Nice to see more horns on the 12v thread. Just finished a 2 way system in which the bass horn doubles as a wheelbarrow. Top horn and electrical gubbins can stash in the horn mouth for transport. Bass horn is rear loaded (like scoop bins) to allow some mids to radiate from the front of the drivers but if I did it again would go 3 way perhaps with a unity horn on top. Sorry can't help with the horn theory as I tend to wing this but I've been surprised at the results in the melodic bass range. MUCH louder than a closed box. Look forward to seeing this one.
AlmostSalty
Registered User Joined: 06 June 2011 Status: Offline Points: 415 |
You would probably be best of buying a wagon to transport your equipment, and consider using a 15" reflex setup for your mids in stead of a horn, wider coverage and less weight than a mid horn. 0r if you want to blast away your neighbors you could get a pair of TMS4s |
Phil B
Old Croc Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2322 |
Have a look at what Coco Poco Loco have used for a festival in Aus.
A pair of the Syntrips over 2 x XOC1 Tapped horns. It sounded awesome for a 4 box set up ! The subs were loaded with B&C SW115s though which would require too much power out of a battery system. I would keep the Syntripps and use a pair of Keystone tapped horn subs loaded with a higher efficiency driver as you suggest.
.p. |
