Wharfedale Focus 18S/218S |
Post Reply | Page <123 |
Hemisphere
rish
Young Croc Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
Shame. Makes me wonder. |
Darkstar
Registered User Joined: 08 October 2014 Location: Italy Status: Offline Points: 326 |
Sorry Elliot but I think you're going a little bit off topic here, what you're talking about is a second step after completing the purchase of the aforementioned equipment. You want to know this kind of details before you buy, if the 1-watt/1-metre data is advertised three times with three different numbers there is no way to find out the correct one other than measuring it yourself. Ears are important, but you cannot invest money on something you have serious doubts about. |
Bass =/= Enough
Whether you buy the loudspeaker design from a manufacture or you build it your self the same thing applies. What is wrong with measuring the loudspeaker in order to find the answer whether you buy a design from a manufacture or if you designed it yourself? Those who measure get the answers and are not perplexed with the three ratings stated from a loudspeaker manufacture. They are also not going to try to extract every bit of SPL from the least amount of speakers without taking distortion and power compression into factor. If you are really interested in a loudspeaker system, you will either borrow or rent two boxes and test it yourself. If the investment is that steep, that is what sound men do. Best Regards, Edited by Elliot Thompson - 24 August 2016 at 9:37pm |
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 539 |
Hmmmmmmmmm |
MattStolton
Back to subject, if you will allow me....
Did an install for a gospel style church, and budget was tight. Used the Wharfedale Pro SI-X range. Those specs are much more "real", and were a pleasure to use and install, and listen to after wards. Old School efficiency, from both the SI-10X and SI-12X, meant we could use smaller amps (mid price Crown stuff), and the little SI-12BX, horn loaded sub, made quite a pleasing noise, and seemed to match with it's published specs. Run off a Soundcraft Si Performer 3, and controlled from Ultradrives, overall exceeded my expectations, and met the client's budget. No failures after 2+ years of hard work. 218s making 140+dB, smells a little fishy, however.
Earplug
No, Wharfdale do/did make some decent speakers, but from what I understand, management has changed.
And then we have BS like this on their site (from the EVP-X MKII page): "The new series serves up to an extra 20% power handling and an additional 32dB SPL over the original EVP-X." Again, doesn´t exactly generate confidence. |
