  New Posts New Posts RSS Feed - Glue and Screws
Glue and Screws
Futendra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Futendra Quote  Post ReplyReply Direct Link To This Post Topic: Glue and Screws
    Posted: 14 May 2017 at 3:41pm
Alright, a very newbie question here. What is the best glue to use? What are the best screws to use? Any first-timer recommendations?
I-shen Soundboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 5:17pm
Glue was discussed recently;
http://forum.speakerplans.com/box-builders-yellow-glue_topic98276.html
...and some thoughts on screws and alternatives:
http://forum.speakerplans.com/what-filler_topic98003.html
Edited by I-shen Soundboy - 14 May 2017 at 5:32pm
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 2:46am
Use screw fix joiner mate PU glue and 3.5x40mm Turbogold screws...
4mm is bolox you need to pilot, PVa is for school girls, buy once buy right!!!
Also I don't mess around with countersinks and Turbogold chops in and leave a nice rough edge for the 2 pack filler to grab....
I use either Brewers' 2 pak, Isopon P38 or plastic padding, any decent 2 pak poly ester filler will do.
If you want to use "tuffcab" or similar  emulsion paints, be awre you need tiny amounts of filler, (hence the 3.5mm TG head sinks nice..
This page was generated in 0.143 seconds.
