  New Posts New Posts RSS Feed - Golden scan 2 to led
Steve20131 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Topic: Golden scan 2 to led
    Posted: 02 August 2016 at 10:52pm
Conversion to 200w led
There bolted to 100mmx100mm aluminium billet but now has sinks n fans,  that was just for lining up and focus,   and cables all tidy now
Edited by Steve20131 - 02 August 2016 at 11:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2016 at 10:55pm
GS3 to 500w is going to be the beast...
n.b if anyone else does this the colimator lens that comes with the large leds you keep and place 22mm away from the double condenser lenses allready in the unit...that took a while.  Other than that an easy job
Edited by Steve20131 - 02 August 2016 at 11:02pm
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2016 at 12:59pm
How are the dichroics with the LED source and the changed output spectrum?
Which LED unit did you use too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2016 at 5:13pm
Very rich,  as the hti.  I will do a side by side test when I'm at the workshop next to get really fussy but I'm well pleased,  even the uv lit up the garden well,  will suit my needs.  I may redesign it to clip in so I can put a 10w 12v chip in for programming (can be powered by the fan smps).
The led is a epistar 22000 lumen 6000k 36v.  I think it's so bright because the lenses catch I would say 95% of the light whereas lots is lost in the fixture with the arc bulbs,  and why they get so hot
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2016 at 8:56pm
what would you say the material cost is of converting one of these?
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2016 at 6:37pm
Hi norty,  I'm back in the workshop in september so will do a side by side and post it.
Hi K.  Edwards roughly 190. The GS3 will be around 250 plus your time,   I would say around a day and a half but I did spend some extra time stripping it right down.  That was the first unit so the others will be less.  I know most would'nt bother but I do really like these and makes them long term cost effective for me.  With the arc bulbs not really something I could afford to play around with
I've also got rid of the iris which as channel 1 I can use on another fixture (24 ch desk in normal mode) :o)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2016 at 6:50pm
Sorry no it's a Jands event 48 so will do all in normal mode I meant...
woody2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2016 at 12:55am
have you reduced the weight?Wink
in time laser light source is the future rather than led
monkeypuzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2016 at 12:47am
almost wishing I still had my stage scans.... full colour mixing.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2016 at 1:00pm
Now I've saved some more pennies just ordered the 500w led and power supply for GS3.  It's the same voltage (70) supply but less watts,  420.  I wanted to make it last longer and guarantee the supply does'nt over power it.
Incidentally the drop in light output is significantly less than the power reduction like for like,  apparently...??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2016 at 1:19pm
& yes woody the weight is severely reduced Beer  Although the 2 is quite light (in context) to begin with,  the reason I bought them over the 3,  carried on my own.  I would chose smaller fixtures but the large leds require a sizeable optical path (from just my experience) to be of any use so the 2 ticked all boxes.
To make sense with the last post there is one GS3 and 7 GS2's.  But the 3 should be considerably lighter as well
Don't know lasers Confused  (probably in the best interest for all!!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2016 at 10:38pm
From power/dissipation calculation the GS3 case might not be big enough for a suitable heatsink and may need to be liquid cooled,  cool Tongue
