  New Posts New Posts RSS Feed - Grill in 186 horn to prevent items getting in?
Futendra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Futendra Quote  Post ReplyReply Direct Link To This Post Topic: Grill in 186 horn to prevent items getting in?
    Posted: 17 March 2017 at 10:11pm
Would it be possible to put a grill where the red line is? To prevent things from getting inside the horn? I really like the look of an open horn, and don't want to put a full grill in. Would this affect the sound quality?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Futendra Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2017 at 10:13pm
Or maybe even better, right at the brace?
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2017 at 10:43pm
Wire mesh would work well and stop alot of the usual fodder getting up there (cans, plastic cups, flyers)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Futendra Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2017 at 4:26am
What would be the best way to attach the mesh? To avoid rattling and/or it coning loose?
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2017 at 10:46am
If you are in the process of building these then you could put a shallow saw cut in the top and bottom panels. Then cut the grill oversize (height wise), and spring it  into the saw cuts so that the grill is slightly convex.
The only problem is that unless you have full face grills people will still use the hornmouth as a cloakroom/drinks store.
Edited by markie - 18 March 2017 at 10:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Futendra Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2017 at 3:08pm
I have no problem with people using them to put stuff on, but I want to prevent any possible damage. Would I have to glue it in place? I feel like it would come loose because of the vibrations...
Edited by Futendra - 18 March 2017 at 4:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2017 at 5:21pm
No chance will come loose ect, if you use a rubberized adhesvise , some out there are silly strong, no bass out there can knock that off..imho
dont forget its not under pressure as such, only air blowing thu the grill
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2017 at 7:03pm
A generous amount of small L brackets evenly spaced around the perimeter holding the mesh should do a pretty good job and be easy to retrofit with a small or right angle screwdriver
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2017 at 1:56pm
might have to do this with ours lol
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
This page was generated in 0.039 seconds.
