  New Posts New Posts RSS Feed - GSUB BEST DRIVER
GSUB BEST DRIVER
raga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote raga Quote  Post ReplyReply Direct Link To This Post Topic: GSUB BEST DRIVER
    Posted: 15 January 2009 at 3:42am
GSUB <=============> WHAT IS THE BEST DRIVER ?
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2009 at 3:49am
What does the plan say? Oh, you're from the US... Might be a prob then. L18-P300 might then be an option...
Or the Fane
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2009 at 3:50am
Or if you have too. P-Audio C18-650LF or C18-600LF wit port 100 deep = General Bass....
wafflesomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2009 at 7:13am
On the cheap, the Selenium 18sw800 does great in a reflex.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2009 at 2:30pm
You can find a variety of suitable drivers in the US. I will try the Peavey Lowrider.
Head of engineering
Bold Audio Inc
www.boldaudioinc.com
http://www.facebook.com/pages/Bold-Audio-Inc/323691856723
FUBARD303 View Drop Down
Contentiously righteous
Post Options Post Options   Thanks (0) Thanks(0)   Quote FUBARD303 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2009 at 11:30pm
go with the p300 you can get em from several online stores.
usspeaker.com
loudspeakersplus.com
just call n BE SURE they have em in stock BEFORE you order n pay.  you just might get  the runaround...
"Always look on the bright side of life" -Brian
dariuzzo26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2009 at 3:31pm
scusate io avrei una domanda sulle misure date dal progetto del gsub--vorrei sapere se quelle riportate sono le misure "finite" nel senso che se mi faccio tagliare i panelli..non rischio poi che non combacino perche non ho aggiunto i 18mm dello spessore del pannello??  vi chiedo quindi le misure "finite" dei pannelli sono??: 2 pann. 1100x536  2 pan. 670x536 e 2 pann. 670x1100???? grazie...premetto che all'interno ci verranno adagiati 2 bei rcf l18p300..aspetto i vostri suggerimenti su misure variazioni e quant'altro a presto..
AHH!! dimenticavo sono un nuovo iscritto quindi salve a tutti!!!e compl. x il sito fantastico!!!EmbarrassedClap
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2009 at 3:50pm
Write in english ;) altrimenti rispondo solo io :D
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2009 at 4:08pm
I would have a regarding question the measures of the "gsub" plan..I would want to know if I make to cut of the panels to the brought back measures..risk that the panels do not coincide? I must add the thickness of 18mm of the panel to those measures or not?.......ufff uff pant pant che faticaccia..ah gia..that tremendous hard work to write in English.Wacko
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2009 at 1:17pm
a me va bene anche una risposta in italiano...basta che sia esauriente..grazie..
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2009 at 3:52pm
someone has never tried the gsub with the rcf l18p300?you would advise the eventual modifications to me to bring to the plan if us they are some?today I will go to make to cut the panels and I would not want to mistake measures… kindly you communicate quickly your councils to me. .non I want to waste money for new panels uselessly...thank alot..and sorryfor my very bad english..
web department
