  New Posts New Posts RSS Feed - GSUB BEST DRIVER
GSUB BEST DRIVER
dariuzzo26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2009 at 4:17pm
nobody wants gives a hand to me?
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2009 at 6:11pm
try simulate it with winsd, what range of frequencies do you want to cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2009 at 8:08pm
I do not have much culture in this field I can only say that I must play de dub and of the reggae….
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2009 at 8:26pm
it's pretty simple learning winisd, by the way do you want to use gsub for midbass like jahtubby do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2009 at 3:14pm
honestly I would want to use them like sub in addition to my system. therefore creed that must cover least… councils?Disapprove
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2009 at 4:23pm
Build the same cab (with the same plan and driver) that you already have so you don't have the phase cancellation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2009 at 7:52am
I will try myself to make thus. since also I have tried to simulate it in winsd but the technical card of the rcf does not supply all the necessary parameters to the simulation… creed…
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2009 at 7:54am
you have read my participation in the post in ciu make the lecture because speaks you only Italian?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2009 at 8:08am
Are you sure? I've just check the technical card and it provides all the parameters, what parameters did'nt you find?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2009 at 5:41pm
someone can explain to me like using the program winisd??? I have not understood nothing to us. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote dariuzzo26 Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2009 at 6:33pm
the parameter supplied from the site rcf they are not sufficient in order to simulate the sub in winisd..those lacking calculate the program independently to them. it calculates but them wrong..how is resolved this problem? someone can send a complete card to me of all the parameters… or at least to help me in some way?
ravit68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ravit68 Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2009 at 4:55pm
Try using a solid middle shelf, no rectangular vents ,ie... the shelf you can see when you look in the port of the cab, and use the Selenium SWS 1100 18' woofer, crossover at 100hz.  _popupControl();
Edited by ravit68 - 06 March 2009 at 5:10pm
web department
