GSUB BEST DRIVER |
Page <123> |
dariuzzo26
Joined: 27 January 2009 Location: italy Status: Offline Points: 15 |
Posted: 04 February 2009 at 4:17pm |
nobody wants gives a hand to me?
bitzo
Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
Posted: 04 February 2009 at 6:11pm |
try simulate it with winsd, what range of frequencies do you want to cover?
dariuzzo26
Posted: 04 February 2009 at 8:08pm |
I do not have much culture in this field I can only say that I must play de dub and of the reggae….
bitzo
Posted: 04 February 2009 at 8:26pm |
it's pretty simple learning winisd, by the way do you want to use gsub for midbass like jahtubby do?
dariuzzo26
Posted: 05 February 2009 at 3:14pm |
honestly I would want to use them like sub in addition to my system. therefore creed that must cover least… councils?
bitzo
Posted: 05 February 2009 at 4:23pm |
Build the same cab (with the same plan and driver) that you already have so you don't have the phase cancellation.
dariuzzo26
Posted: 06 February 2009 at 7:52am |
I will try myself to make thus. since also I have tried to simulate it in winsd but the technical card of the rcf does not supply all the necessary parameters to the simulation… creed…
dariuzzo26
Posted: 06 February 2009 at 7:54am |
you have read my participation in the post in ciu make the lecture because speaks you only Italian?
bitzo
Posted: 06 February 2009 at 8:08am |
Are you sure? I've just check the technical card and it provides all the parameters, what parameters did'nt you find? |
dariuzzo26
Posted: 14 February 2009 at 5:41pm |
someone can explain to me like using the program winisd??? I have not understood nothing to us. thanks
dariuzzo26
Posted: 14 February 2009 at 6:33pm |
the parameter supplied from the site rcf they are not sufficient in order to simulate the sub in winisd..those lacking calculate the program independently to them. it calculates but them wrong..how is resolved this problem? someone can send a complete card to me of all the parameters… or at least to help me in some way?
ravit68
Posted: 06 March 2009 at 4:55pm |
Try using a solid middle shelf, no rectangular vents ,ie... the shelf you can see when you look in the port of the cab, and use the Selenium SWS 1100 18' woofer, crossover at 100hz.
_popupControl();
Edited by ravit68 - 06 March 2009 at 5:10pm |
Page <123> |
Tweet
