gsub cutsheet |
Post Reply | Page 123> |
RUS
Posted: 06 March 2009 at 9:46pm |
i hope this works cut sheet for gsub.
Stray-Sounds
Old Croc Joined: 13 March 2008 Location: Wales Status: Offline Points: 2426 |
did you make it?
<a href="http://www.soundhirewales.co.uk/">PA & Lighting - Sound Hire Wales</a> |
RUS
hi. what the gsub or the plans i just posted.
Stray-Sounds
the cutsheet
RUS
hi stray sounds i did. you should find that it right down to the mm.
Stray-Sounds
I think your cutsheet is wrong rus.
the bigger sheet shows 1136 which is bigger than the whole cab. that sheet should be 1064 geth |
RUS
hi gethin thank you for pointing that out to me. sorry your right my cut sheet is wrong but it should'nt be 1064 like you say it should be 1100.
i feel like such a dick i got it wrong because of the way i was looking at the plan.
Stray-Sounds
I cant believe how confusing im finding this box. its so simple, any horn box must be hard work!
RUS
there not really hard work i just looked at the plan a little wrong. i've checked the plans over again and the only mistake i made was the top and bottom instead of being 670x1136. it should be 670x1100. all the rest of it is right. i've double checked it. and it is a really simple design (i hope i wont be eating my words again) no i wont. thanks again gethin for pointing that out for me. |
RUS
ps. ill draw up a new cut sheet with the correct measurement.
Stray-Sounds
Another thing i'm not too sure about is the baffle.
The length of the cab is 1100. so 1100 - 36 (2 x 18mm each end of the box) = 1064 then 1064 - 36 again (the ports) = 1028 then 1028 - 120 (port size) = 908 so 908 divide by 2 = 454 So should the baffle be 454x500mm ?? Geth |
RUS
hi.
gethin you do realise that the total lenght of the box is 1136mm.
