  New Posts New Posts RSS Feed - G-SUB CUTSHEET
G-SUB CUTSHEET
 Post Reply Post Reply Page  <1 2345>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2015 at 9:22pm
or rebated?
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2015 at 4:52pm
Originally posted by Dub Specialist Sound Dub Specialist Sound wrote:
why is my cut list diffrent to this one and orther on here? this isnt right some how[DI
is this cut-sheet for butt joint?
hay dub it is a plan for standard butt joint build it is to the exact plan of rogs is there anything in particular I can help you with ?
Techno
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2015 at 5:08pm
Yes Rus if poss just want to check it to my cut list i did my self , butt joined
its probley me bro, not borthered about the internal bracing as we know some do it a little diffrent so just to keep it simple
mine
670mm   x 536mm    x 2  (Top and Bottom)
618mm   x 1100mm  x 2  (Side Panels)
1100mm x 500mm    x 1  (Back Panel)
490mm   x 500mm    x 2  (Front Baffle's)
500mm   x 193mm    x 2  (Shelf Ports)
193mm   x 120mm    x 3  (Port brace) Extra one for the middle, just my way
Edited by Dub Specialist Sound - 16 April 2015 at 5:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2015 at 5:09pm
Measurements as the box in standing up, as we know sme do as the box is lying down
nice one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2015 at 9:36pm
why are your baffles 472mm
are you building them from the side of baffle or flush on the inside
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2015 at 9:39pm
just calulated it
your putting the port shelfs on the side of the baffles
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2015 at 9:40pm
so mine is correct littaly by the plan
hang on no im not lol i tied man lol
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2015 at 9:07pm
Dub stop talking to your self
I've tried to work it out I think I understand some of what you did, you can give me the external dimensions of your box if you want and the meterial thickness and I can work out the litre box you have and compare it to the original I think your box dimensions are slightly smaller than the original plan,
A lot of people seem to not add the side parts of the port making the port 36mm wider I don't know why they do this
Techno
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2015 at 9:15pm
haha tell me about it Rus haha
i think ive got it now , what it is when i zoomed into the plan, i realised some put them ports shelfs on the inside of the baffle and some put it on the outside
thus making the baffle dimesions a little size different, not the over all box dimensions of 1136
correct?
cheers rus
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2015 at 9:17pm
yes got ya on the side port , making the port hole slighty larger , than on the plan
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2015 at 9:32pm
Yes the plan says to put the baffle butting up against the side of the port,
It's difficult for me to work it all out as I'm on a mobile phone with a small screen
Techno
