Gsub: driver and modifiactions for kick duty |
Post Reply | Page 12> |
rolandoalphonso
Registered User Joined: 02 September 2009 Status: Offline Points: 17 |
Posted: 29 June 2015 at 5:14pm |
greetings forum,
i'm about to build 2 g subs for kick bins. (playing ruffly in the area 60 - 160 hz) -what would be the best drivers? pd 186? fane xb? others? -would it be a point to make the enclosure a little smaller as to get more push & throw? if yes, would i have to alter also the ports? thanks for any advices, best regards
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5176 |
For such a limited bandwidth, you are better off with horns. Possibly the USB. Best Regards, |
rolandoalphonso
Thanks Elliot, but I'm anyway looking at the reflex for now.
nickyburnell
2 x 15 then, with 3" coils
Exactly. This is what a pair of Double Fifteen Reflex bins playing kick sound like sitting on top of subs with the microphone 3 metres away . Best Regards, Edited by Elliot Thompson - 29 June 2015 at 10:51pm |
sn95
Registered User Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
Or run the G sub as normal
rolandoalphonso
Ok gsub as normal but which driver is the best?
nickyburnell
GSub is too small, sorry, I've owned them with xb and 186, 4 x separate 200l with same drivers gives more energy, sub and stackabilty. Bigger 2 x 18 needed with todays drivers IMHO
https://martin-audio.com/products/WS218X/ 100mm deeper 25mm wider. Gsub loses a lot of space with that bracing pattern which could be made simpler |
DanielIt
Registered User Joined: 11 September 2013 Location: Italy. Status: Offline Points: 273 |
Hey guys..i am sorry i dont want to hijack the thread,just asking if anyone has build up half Gsubs and how it sound with Void V18.I might go that route soon because the gsub is way too heavy to 1 man lift.
Measure twice...cut once.
nickyburnell
V18 1000? NOT a reflex driver. V18 1200 would sound nice, but they don't make them any more
DMorison
What Nicky B said, plus..... V18 (1000 at least) is not exactly the driver to choose if you want to save weight. Ciare NDC and NDH 18's model quite well in typical vented boxes and are half the weight of the Void. David.
rolandoalphonso
so ok, g-sub is not he best for kick bass. but since i've already cut the boards (!) and want to try it, but thinking i should modify it :
1) would a smaller box volume make a better kick? 2) would a fane xb 1000 be a well suited driver for this puropse? (i've read in another gsub thread on this forum that it got a more tonal sound and better in higher bass frequencies than the lowest end), compared to for example the pd186. any comments? |
