Guide to WinISD Pro and Hornresp |
Page 123 7> |
tkollen
Joined: 22 hours 36 minutes ago Location: Great Falls, VA Status: Offline Points: 1 |
Topic: Guide to WinISD Pro and HornrespPosted: 22 hours 16 minutes ago at 11:44pm |
Can anyone advise me on the following:
I am trying to simulate a horn tweeter using Hornresp. The driver I am using is very unconventional - It is a small modulated corona plasma flame coming from a tungsten rod tip. You could say that the diafragm is completely without mass. I intend to insert this tip into the throat of a ceramic horn. The lower cut off frequency without horn is ca. 5000 Hz. I want to lower this frequency to ca. 2000 Hz. Is Hornresp suitable for this task and if so I am looking for some guidance on what parameters to use, or is there a better simulator out there for this task? Anyone please? |
HighGradeBlazer
Joined: 12 December 2011 Status: Offline Points: 10 |
Posted: 17 December 2011 at 6:17pm |
Very helpful...thanks :)
mobiele eenheid
Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1068 |
Posted: 10 September 2010 at 3:10pm |
Two times the PD186 in the G-sub should be close to 100 dB/W/m. Other drivers might give less or better results. WinISD Pro is a bit pessimistic about band pass enclosures, you could simulate using Hornresp. Regards Johan
Fiore_89
Posted: 10 September 2010 at 12:54am |
Hi, thanks for this complete guide to winISD but i don't understand a thing...
If I simulate one of reflex or bandpass plans as Gsub or X1 the SPL response graphics in WinISD show me a line always about 3dB less than original SPL response graphics reported on the plans paper of Rog, why?
I'm new and my question would be trivial but pleese reply me!
thanks
teslaman
Joined: 11 June 2009 Location: Huntingdon Status: Offline Points: 188 |
Posted: 10 June 2010 at 11:29am |
Brilliant, many thanks!
Centauri
Joined: 29 November 2004 Location: Australia Status: Offline Points: 1322 |
Posted: 10 June 2010 at 9:25am |
Now at http://www.dmcbean.bigblog.com.au/index.do
teslaman
Posted: 10 June 2010 at 9:20am |
Has the Hornresp page moved? I was looking to download and google suggests http://mywebsite.bigpond.com/dmcbean/ is the place to go but I just get the following error:
HTTP Server Error 503No available server to handle this request Anyone know where I can download from? Cheers. |
mobiele eenheid
Posted: 04 June 2010 at 1:56pm |
2 pi
Regards Johan
airbell
Joined: 11 June 2009 Location: Berlin, Germany Status: Offline Points: 219 |
Posted: 04 June 2010 at 12:45pm |
short question: are the graphs in WINISD in halfspace (2pi) or full space (4pi)???
thanks
mobiele eenheid
Posted: 17 April 2010 at 11:40pm |
Now it is, thanks for the note.
Best regards Johan
Saul
Posted: 06 April 2010 at 4:47pm |
hornresp download not working....
mobiele eenheid
Posted: 17 February 2010 at 4:31pm |
The latter (0 - peak)
Best regards Johan
Page 123 7> |
Tweet
