  New Posts New Posts RSS Feed - Guide to WinISD Pro and Hornresp
 Post Reply Post Reply Page  <1 78910>
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2012 at 10:51am
did you state 2 x drivers? Embarrassed
winni View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote winni Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 1:41am
Yes, I did Smile
So here is the prediction with maximum SPL of 300L G-SUB with double 18LW1400 - without any EQ:
Is it possible to improve it with additional EQ settings? Not sure how can eq affect on sound...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 3:32am
Hi.
The G Sub is a small box to house two 18 inch drivers. The box may be the limiting factor why you cannot get anything below 50 Hz without equalisation.
Best Regards,
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2013 at 12:49pm
Anyone elae having trouble downloading hr?
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
Avatron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Avatron Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2013 at 1:26pm
Yes, i also cant download hornresp! Searched on google, tried many links but none of them work!
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2013 at 2:01pm
As per link on last page, try http://www.hardware-test.org/mcbean/Setup.exe
Just downloaded version 32.2 from this link.
Looks like the hornresp.net.ms domain has expired
Edited by Centauri - 28 May 2013 at 2:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Avatron Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2013 at 3:17pm
thanx centauri! Thumbs Up
Perfect, now i can try to simulate a stack of Es18BPH's!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Avatron Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2013 at 3:25pm
Damn! It doesn't work! Hornresp tries to open and then it shows a failure!
I must say that i have a macbook and use wine emulator. Maybe thats the resason that the program
wont start!
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2013 at 3:44pm
i got one version of hornresp working once with one version of wine... can't remember at all which or when.. but i did post about it. possibly here, possibly on diyaudio forum too. google and you won't find much, but you should find some chat about it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Avatron Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2013 at 3:59pm
thx cravings! Found it don diyaudio. Now i will try an older version of wine. (1.2.3)
Actual version is 1.2.5.
Hope it works!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Avatron Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2013 at 7:05am
Bad Luck for me! Cant get hornresp running! Always the same, hornresp tries to open, and then failure -
it closes! Angry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2013 at 7:28am
Might have something to do with the VB6 runtimes under Wine.
