  New Posts New Posts RSS Feed - Halfinator Build - For sale - 28/2
 Post Reply Post Reply Page  <12345>
roopes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roopes Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2016 at 1:56pm
Originally posted by lutkeveld lutkeveld wrote:
Did you already fix your MaxAmp problem?
Good rule of thumb for playtime with a MaxAmp on a 12v lead acid battery in hours is:
Maximum volume: Ah*2
Normal volume: Ah * 8
The problem is not yet fixed, but accusafe sent me a new amplifier that im going to test out.
And if u want to calculate other amplifiers other than maxamp? is there a way to do that?
lutkeveld View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2016 at 3:55pm
There are a lot of factors to consider:
-Battery type (voltage, max discharge %)
-Amplifier (idle current, max output)
-Volume (how loud you're playing)
-Power usage external components (BT modules, voltage regulators)
-Type of music that is played (mainly crest factor)
There is no one easy formula unfortunately. I'll explain how each factor affects playtime:
-Battery type: higher voltage results in higher idle loss, but allows for higher max output power (which in turn causes higher power draw at max volume)
-Amplifier: on low to medium levels (<1W) idle current dominates the equation.
-External components: things like DC DC converters, USB chargers etc consume quite a lot of power compared to an amplifier
-Type of music: low crest factor (lower average to peak difference) results in higher power draw, clipping can lower the musics natural crestfactor.
As a rule of thumb formula (only amplifier, no significant external power users):
High volume: Useable battery capacity in Wh divided by (total max output / 8)
Low volume: Useable battery capacity divided by amplifier idle power
Post Options Post Options   Thanks (0) Thanks(0)   Quote roopes Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2016 at 4:46pm
Thanks for a good answer!
Post Options Post Options   Thanks (0) Thanks(0)   Quote roopes Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2016 at 8:01am
Update 2016-02-16 see first post
Post Options Post Options   Thanks (0) Thanks(0)   Quote roopes Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2016 at 8:27pm
At 80% volume on my iphone 6s the sound is starting to become crap, is this normal?
Ganon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ganon Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2016 at 7:46am
Yes. The Iphone has it's max output just around there. The last three-four dots are an over output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roopes Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2016 at 7:47am
Thanks Ganon! Then it's all good, and it sounds fantastic for being a portable 270$ homemade speaker!
Post Options Post Options   Thanks (0) Thanks(0)   Quote roopes Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2016 at 1:48pm
Im interested in building a full boominator, so if anyone wants to buy a halfinator then this is for sale.
Located in Sweden
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ganon Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2016 at 6:47pm
What about building one more Halfinator and use some Locks/Henges/butterflylocks, to connect them, so that you have a boominator that can be split up to a Halfinator.
Then it's possible to use them as monitors or only have a halfinator with you, if its only needed. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote roopes Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2016 at 6:48pm
Yea thats a good idea actually! I already have the wood cut up for one more halfinator
Edited by roopes - 19 February 2016 at 6:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ganon Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2016 at 6:57pm
I am planning to make build like that, a Multinator. :P
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2016 at 7:06pm
Or you could upgrade the battery/amplifier. A 24V the Halfinator will be as loud as the full-size on 12V.
