Halfinator Build - For sale - 28/2 |
Post Reply | Page <1 2345> |
roopes
Registered User Joined: 04 January 2016 Status: Offline Points: 83 |
What would be the best amplifier and battery for the 24v version?
Edited by roopes - 19 February 2016 at 7:53pm |
roopes
Can I mount a DC-DC converter and have some kind of switch to turn it on so it runs on 24v when switch is on and 12v when its off, is that possible to make? How do i wire it in that case?
2x7,2aH SLA batteries, DC-DC converter to 24v will that make it play for 8h? Edited by roopes - 19 February 2016 at 8:26pm |
slaz
The Sure ST508 is tried and tested here. Wel-behaved, reliable at 24V, 4R loads |
slaz
?? - with 2 x 7.2Ah batteries you have 24V 7.2Ah right there - connect em in series and done ! |
perjespersson
New Member Joined: 22 February 2016 Status: Offline Points: 2 |
Nice work! Just have one question, you also seem to be swedish, so where did you buy the resistsors? Can't find any matching anywhere
roopes
Att köpa: http://www.conrad.se/H%f6glastmotst%e5ndVitrOhmCR25405T47R47OhmAxialh%e5l lmonterade2.5W1st.htm?websale8=conradswe&pi=459287&ci=SHOP_AREA_17441_02 41366 alt http://www.ebay.com/itm/5pcs47ohm13WMetalFilmResistor3Watts47R/3711467349 14?hash=item566a11bd42:g:rWUAAMXQBg5RybhC |
perjespersson
Göttgött! Men måste inte motståndet vara metallfilm eller går detta lika bra? (Det från conrad då)
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
Jag tänker att det är ingen differens är det metalfilm eller inte. Men jag är inte 100% säkert om det. Om jag försår din fråga rätt Kul att skriva på svenska lite om jag är inte mästaren av det
Edited by app - 22 February 2016 at 11:09pm |
"what!?"
roopes
Jag har fått till svars att det skall fungera med båda
roopes
Update first post 2016-02-23
roopes
update 2016-02-28, see bottom of the first post
malmskov
New Member Joined: 27 April 2016 Status: Offline Points: 1 |
Is it possible to maybe get the measurements you used? :)
