  New Posts New Posts RSS Feed - HD15 Driver Sims
HD15 Driver Sims
 Post Reply Post Reply Page  <1234 9>
ashnono View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashnono Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2005 at 6:55am
obertons too if you get a chance mate.
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2005 at 10:00am
Nice one dave fancy trying some 12"s in there just for kicks?
Stu
All you need to know is:
My acts:
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2005 at 11:28pm
ouch images broken?
speed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote speed Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2005 at 6:40am
can you simulate this please
peavey 1505 ka
http://www.peavey.com/support/technotes/misc/blackwidow.cfm
Dave Slater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2005 at 8:35pm
as you wish...
but you'd be better off with the 1505-8DT as it's got 4.8mm Xmax compared to 2.6mm (practically the same response for both so i couldn't be bothered posting another pic)
having said that the continous rating is only 350W for either of them so you're not going to get much out anyways
dave
ps. more sims to follow i got side tracked...
Post Options Post Options   Thanks (0) Thanks(0)   Quote speed Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2005 at 12:39pm
than you ver mutch
do you think dis driver work better in this horn as an vented box
maybe an other horn is better
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2005 at 3:34pm
Ummm, is this always a 'one HD15' simulation? If yes, why not using always four HD15? Who puts only one? :)
muri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote muri Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2005 at 1:40am
can you simulate this speaker please
RCF L15P300
http://lsb1.free.fr/l15p300.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote speed Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2005 at 6:40am
dave can you posts the input parameter of the peveay please
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2005 at 11:01am
it was originally done to match the plot rog put up with the design
1 bin in 1/4 space which is the same as 2 in half space (what we use above one X1)
unfortunately horn response won't allow multiple bins when the horn is sectioned like this but it would let you put 1 bin in 1/8 space to give you the plot of 4 in half space
there's nothing to stop anyone using the horn dimensions and doing it themselves or am i being too lazy?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2005 at 11:04am
peavey 1505 KA
Sd:  800.00 cm^2
Vas:  187.00 l
Cms:  2.09e-04 m/N
Cas:  1.34e-06 m^5/N
Mmd:  49.04 g
Mms:  61.84 g
Rms:  2.13 Ns/m
Fs:  44.3 Hz
Bl:  15.70 N/A
Re:  5.30 ohm
Qms:  8.10
Qes:  0.37
Qts:  0.35
Pmax:  350.0 W
Xmax:  2.60 mm
muri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote muri Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2005 at 1:10am
Hi Dave
Could you please simulate the RCF L15P300 in the HD15. I have two speakers at home and I dont know would they be good for the HD15.
here the parameters
speakerplans@redhotmail.net
