  New Posts New Posts RSS Feed - HD15 Driver Sims
HD15 Driver Sims
 Post Reply Post Reply Page  123 9>
Dave Slater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Topic: HD15 Driver Sims
    Posted: 13 September 2005 at 1:07pm
using horn response and the measurements from our HD215's i've been able to simulate the HD15 using conical sections as an approximation of the exponential horn
first off the input screen :-
and the plot for the Eminence Kappa 15LF (95dB, 600W, 5.5mm Xmax)
i'll break the sims down by manufacturer over the following posts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2005 at 1:23pm
Precision Devices
PD 152 (99dB, 400W, 5mm Xmax)
PD 153ER (99dB, 400W, 5mm Xmax)
PD 154 (99dB, 500W, 6.5mm Xmax)
PD 156 (97dB, 650W, 6mm Xmax)
PD 158 (98.5dB, 600W, 4mm Xmax)
PD 1550 (99dB, 600W, 8mm Xmax)
PDN 15SB40 (98dB 600W, 6mm Xmax) - Neo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2005 at 1:48pm
P.Audio
SD-15 (97dB, 600W, 5mm Xmax)
P-15N (97dB, 600W, 5mm Xmax) - Neo
SN-15 B (99dB, 400W, 3.5mm Xmax) - Neo
C15-500 LF (97dB, 500W, 5mm Xmax)
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2005 at 2:27pm
Nice one Dave, can one of the mods sticky this now please
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2005 at 2:29pm
Nice work!
Edited by mobiele eenheid
angus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote angus Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2005 at 2:43pm
Second that - good work! These will be next on my build list me thinks. Almost nothing but rave reviews from those that use them.
Anyone care to post about the plots vs. actual listeniing experience? (for their genre of music)
Cheers,
Angus
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2005 at 4:33am
Beyma
115NdW (97dB, 700w, 8mm Xmax) - Neo
15G40 (97dB, 700W, 7mm Xmax)
15G450/N (98dB, 750W, 6.5mm Xmax)
15LW30 (99dB, 450W, 7mm Xmax) - Neo
15LX60 (98dB, 700W, 9mm Xmax)
15P1000 (97dB, 1000W, 8mm Xmax)
SM115/N (98dB, 400W, 5.5mm Xmax)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2005 at 8:54am
Fane
Colossus 15B (98dB, 400W, 4mm Xmax)
Colossus 15B-600 (99dB, 600W, 5.7mm Xmax)
Colossus 15XB (97dB, 600W, 7.2mm Xmax)
Crescendo 15B (96dB, 400W, 4.7mm Xmax)
Pinheiro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinheiro Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2005 at 9:14am
Hi Dave
Very good Job
please can you do the same whiad DAS speakers (15G,15S,15GN) might be interesting for the rest off the forum members
many thanks
Yours Vitor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2005 at 11:34am
i'm working through as many manufacturers 15"s as poss i'll get to them eventually
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2005 at 12:35pm
RCF
L15/554K (99dB, 600W, 5.8mm Xmax)
L15P200AK (95dB, 800W, 9.8mm Xmax)
L15P540 (98dB, 500W, 6.5mm Xmax)
L15S800 (99.5dB, 700W, 5.5mm Xmax)
LF15G401 (97dB, 800W, 8.5mm Xmax)
LF15N401 (97dB, 900W, 8.8mm Xmax) - Neo
LF15X400 (97dB, 800W, 8mm Xmax)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2005 at 4:55pm
B&C
15PL100 (97dB, 700W, 7mm Xmax)
15PLB76 (100dB, 400W, 5mm Xmax)
15PS100 (94.5dB, 700W, 8mm Xmax)
15PS76 (99dB, 550W, 7.5mm Xmax)
15TBX100 (96dB, 1000W, 9mm Xmax)
15PZB100 (97dB, 700W, 8mm Xmax)
15HPL76 (99.5dB, 350W, 4mm Xmax) - Neo
15NDL76 (99.5dB, 500W, 7mm Xmax) - Neo
15NW100 (97dB, 800W, 9mm Xmax) - Neo
15NW76 (100.5dB, 600W, 8mm Xmax) - Neo
web department
