  New Posts New Posts RSS Feed - Hd15 - my versioin
Hd15 - my versioin
 Post Reply Post Reply Page  123 14>
Rog View Drop Down
Rogers Archive Posts
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rog Quote  Post ReplyReply Direct Link To This Post Topic: Hd15 - my versioin
    Posted: 11 January 2005 at 12:27am
bass horn hd 15
http://photofile.ru/default/do.php?id=5082059#sm
________________________
may horns plans
http://www.tda-audio.photofile.ru/
freddyi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2005 at 5:04am
awesome folded horn work and very nice tube amplifier  - assume push-pull pentode (?)
lots of plans   - ladies in ads look nice too
What is the blue folded horn?
Is your HD 15 the brown-colored wood horn?
(got any Ivan Kozlovsky recordings for the rear-load hifi horn?)
Heres plans for 18" Karlson-type by Cetec-Gauss
http://home.earthlink.net/~buddhaboy2/GK
Heres what I'm listening to tonight:
http://home.earthlink.net/~buddhaboy2/18T.jpg
the slotted waveguide is very good sounding.
Heres another K-coupler built by a friend:
http://home.earthlink.net/~buddhaboy2/HAX2
Best wishes from US
Freddy
Edited by freddyi
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2005 at 4:25am
my version HD-15 SMOLL
plans
Edited by TDA-Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2005 at 4:44am
plans
Edited by TDA-Audio
ricky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricky Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2005 at 3:30pm
Nice job.. what woofer do you use?
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2005 at 4:33pm
Visaton BGS-40 (right?). Awefully nice measurement software you have there. Any indiactions of performance in a stack?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2005 at 4:37pm
woofer-
Boke-Audio (china) 140$. model LB1570-100-220
http://www.bokeaudio.com/speaker/lb.htm
http://www.bokeaudio.com/speaker/andi/LB1570-100-220.gif
LB1570-100-220
Model: LB1570-100-220
Nominal Diameter: 380mm, 15inch
Retd Impedance: 8 ohms
Power Capacity: 600 watts
Sensitivity(1w/1m): 98±2dB
Frequency Range: 30-1500Hz
Voice Coil Diameter: 100mm, 4inch
Magnetic Assembly Weight: 3.4Kg
Magnet Diameter: 220×127×25mm
Product Net Weight: 11.8Kg
Resonance Frequency: Fs 30.3Hz
DC resistance: Re 5.5 ohms
Mechanical factor: Qms 4.54
Electrical facto: Qes 0.27
Total factor: Qts 0.26
BL Factor:
BL 22.4 N/A
Vas 211.1 L
Rp 86.7 ohms
Lp 105.6 mH
Cp 366.5 ?F
Le 1.7 mH
Mms 129.2 gr
Edited by TDA-Audio
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricky Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2005 at 5:46pm
How does the it sounds? Do I smel alot of kick? Have you tested and with other drivers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2005 at 12:38am
>>>How does the it sounds?<<<
good SOUND.
>>> Have you tested and with other drivers?<<<
yes Celestion
http://professional.celestion.com/pro/pro_components/truvox/ detail.asp?ID=15
- vere bad
>>>you from were did you start to desing a box like this, what program did you use?<<<
No soft use.
>>>did you measure and the SPL?<<<
Is not present but shall soon try
Edited by TDA-Audio
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2005 at 9:33am
Could work even better than the original HD15 because of more symmetrical loading of the speaker.
Edited by JD01
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2005 at 12:00pm
There is no area of a mouth less
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2005 at 12:07pm
Culem - please here I spread it for not sale download (I in fact from Russia)
LspCad 5.25 pro
http://www.igolkin.com//soft/Tda-audio/upload/LSPcad-Pro5.25 .rar
   JustMls plugin
http://www.igolkin.com//soft/Tda-audio/upload/justmls.rar
Edited by TDA-Audio
