Hd15 - my versioin |
Page <1 34567 14> |
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 29 July 2013 at 6:11pm |
Yes havnt seen them in a while but nice for the money :-)
im sure a comunity bph is a good idea Edited by Mark James - 29 July 2013 at 6:12pm |
insert silly sentence here
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 29 July 2013 at 6:22pm |
Which is what I'm proposing with this http://www.freespeakerplans.com/forum/44-roots-culture/20372-15-bph-kick-for-scoops |
Mark James
Posted: 29 July 2013 at 6:32pm |
I like the idea would work with flh subs too
levyte357-
Posted: 29 July 2013 at 6:46pm |
Also "plenty" of drivers that would work, from cheap (ferrite) to very expensive (Neo) range. |
bee
Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4549 |
Posted: 29 July 2013 at 6:54pm |
defo why not, the difference in the plott I posted is.... nothing one has just had smoothing added, this is what has been done to the plott u posted lev, going back to the phone call with you, I built the design you posted a few years back from mdf, and its on par with a hd15, but not an improvement on the hd15.....
graphs even an rta one can be incorrect, the second point about the graph I posted is, looking at the graph im well down in the 150hz to 10k hz compared to the bass, this was not so, as mic placement has a massive effect on any reading taken.... ok its a plott of a complete system, but still highlights how a plott can look very different by adding smoothing and placement of mic.
levyte357-
Posted: 29 July 2013 at 7:03pm |
Yep plot doesn't tell full story, but it is a necessary start. Take a look at this thread, HD15 Sims thread, http://forum.speakerplans.com/hd15-driver-sims_topic2617.html At least a 100 different driver plots of the HD15 cab, from some very knowledgeable people, who often use HR, to design BPH hybrids. Need HR plot of TDA-15, to even start comparing it with HD15 Bee, this can't be done on one person's opinion, or findings. |
Teunos
Joined: 23 November 2008 Location: The Netherlands Status: Offline Points: 1832 |
Posted: 29 July 2013 at 9:39pm |
If you want i can fully draw it out in sketchup with every panel being a different part, and sim it in hornresp. Takes me roughly half an hour to do it accurate. Will be by tomorrow evening, first I've got some tops to paint
Best regards,
Teun. |
levyte357-
Posted: 29 July 2013 at 9:44pm |
Teunos
Posted: 30 July 2013 at 9:54am |
Paint does not arrive for two hours, or at least that's the courier's e.t.a.
So first up the raw panels with measurements. The angle of the baffle was a little ill-defined so i chose 32 degrees, slightly lower than it looks like in the plans. This can be altered easyli though. The measurements of the horn path and chamber volumes, bruto=gross. What it COULD look like And finally the sim. So i deducted roughly 5Lt for the rear mounted driver, and added 3Lt to the front chamber due to the volume inside the cone. So at first as a raw sim it doesn't look half bad, but surely not the 60Hz shown in TDA's measurement. Sim made in 2pi.s.r. which is 1 cab placed on the floor, or 2 cabs placed on top of subs. The driver used for the sim is the RCF L15S800, which is quite a hard hitter (4''VC, Stiff suspension and very stiff cone, strong motor) when placed in BPH's that gives a really, really punchy sound. Other drivers with softer suspension that sound more hifi may be more suited for Reggae like kick style i guess Lev prefers? Any driver suggestions? Also, my BPH's i built a year ago are pretty much the same layout etc, only 400mm internal height and slightly deeper, and they go nowhere near 60Hz flat, more like 80Hz flat which is what these seem to do as well. Note; My BPH's measure the same as my sim They are most outer left cabs on top of the subs in the centrestack in the pic below. Edit: replaced the sim screenshot with the proper one.
Edited by Teunos - 30 July 2013 at 10:46am |
Best regards,
Teun. |
all bass
Joined: 11 October 2012 Location: the Netherlands Status: Offline Points: 1845 |
Posted: 30 July 2013 at 10:26am |
Awsome, good job Teun!
Very nice to see the pic with the measurements, makes it a lot clearer for me how to get HR input data of existing cabs or drawings. |
bee
very nice cad work there
bee
Posted: 30 July 2013 at 10:27am |
so the sim reflects the rta hear to
Edited by bee - 30 July 2013 at 10:30am |
Page <1 34567 14> |
