  New Posts New Posts RSS Feed - HD15 VS G SUB FOR DUB MUSIC
dreadsoul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dreadsoul Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2015 at 7:07pm
Ok, but i have a special Price for the rcf Here in italy. Do you think that tune the driver at 35 hz and use it in the range of 90 180 is not good?
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 25 September 2015 at 7:17pm
its all about compromises imo..
a driver that will work well in a given (small) volume tuned low wont sound good above 100ish hz, a driver in the same cab thats able to offer proper lowmids would bottom out quickly at that tuning as its not supposed to be used that low.. Same driver will excel the overall performance of driver A if tuned according to real capabilities.
In short, you wont get a efficient 30hz 15" ported cab performing equally above 100hz afaik..
(ported horn in multiples maybe but not a bog standard reflex)
Try 45ish tuning and a efficient driver rather than seeking for lowest response possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dreadsoul Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2015 at 6:02pm
Ok, but in the Rog's plan of the G sub the X Over suggested is at 180 Hz for these drivers:
Pd 186, Rcf l18p300 and Fane Colossus 18 XB.
So, look to the spec of the RCF (also simulated with WINISD) the driver can works very well from 90 to 180 Hz.
Why did you say that the sound isn't good above 100 hz?
If I use the original plan with RCF l18p300 it should run up to 180 Hz.. or not?
Reon9467 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reon9467 Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2017 at 5:24pm
What size sheets of wood do you buy when building them boxes and how much of them? Thanks
