Height adding box or something else? |
Post Reply | Page 123> |
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
Posted: 27 January 2015 at 5:44pm |
Greetings!
What kinda solutions have you used when you needed to get midtops higher than they are? When I stack my subs and put the tops on em they are a bit too low blasting straight to face. Would be nice to get them a bit higher. Should I just make a "box" or what... Thanks! |
"what!?"
cookie-dj
I've seen where people have made tall tilt boards. not sure how they lock the midtops onto the boards though.
You can't polish a turd!
bass*en*mass
are pole mounts an option?
adam hall sm707 for the tops, sm20 for the subs.. you get the drift.. |
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
Build more subs
Reverence Sound system
app
I dont want poles. Building a box would take some space so need to find a solution which would not take a lot of space but would do the job. Maybe a "box" without sides...That would be kinda wobbly thou I think... Like this ] if you rotate that anticlock wise... One option would be to make/find a box for the wires etc and use that as the height adding box. |
"what!?"
app
This is not a common problem if your system is 3way but 2way is a different thing.
What options is there than poles or a box of somekind? Of course it should look nice too... |
"what!?"
app
...and it should not be something that rattles...
"what!?"
pfly
You don't want poles = moar subs!
VERY simple. |
app
Need to get some € stashed before I can do that... It is in my plans thou. Then Id need another amp too. And after that I might need more midtops and it never ends,I bet you know it |
"what!?"
Adam_Iron_Horse
Old Croc Joined: 02 January 2010 Location: Scotland Status: Offline Points: 2043 |
Basically sounds like poles are exactly what you need, add height take up no room, don't look terrible and don't have to worry about ratcheting the tops to the subs.
can just build a box to put under it if you want, maybe make it an ideal size to fit your top inside it for protection when its being moved? or yeah, more subs Edited by Adam_Iron_Horse - 27 January 2015 at 7:12pm |
Kryptonik Sound Kollective
www.facebook.com/kryptoniksoundkollective |
app
Thats what im talking about Great idea! That way it dont take a lot of extra space! |
"what!?"
Adam_Iron_Horse
haha sorted! |
