  New Posts New Posts RSS Feed - HELP!!! DOUBLE HORN 18 DESIGNS
rich-ind.st View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich-ind.st Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2005 at 7:12pm
the beyma lx60 range are nails, got 4 of the 12's in a pair of dual bp/horn hybrid subs, makes me wanna hear a lab sub for comparrison
would be good fun to knock off a copy of danleys b-deap and bung a pair of them in, i can see why he reakons there is no longer a huge need for 15 & 18 inch drivers.
if you are set on dual 18's i'd at least try modelling the beyma lx's anyway
...they gave you what?
DJ Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2005 at 11:36pm
Hi I have made the Selenium double 18 boxes they are awsome!
They can be viewed on e-bay
I am selling them
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2005 at 11:55am
I am selling them
Are they still for sale ? Please put a link up here so we can check it out.
mans1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2005 at 12:22pm
Can't find anything on ebay..........
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2005 at 12:25pm
Ahh....forgot he's in the states.
Item no.
7357471742
Edited by mans1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2005 at 1:40am
OK, so anyone here willing to give a quote to build a pair of these beasties ? (wire'd, wheel'd, trimite'd, handle'd and dual speakon'd, of course)..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2005 at 11:24am
the angles get goofy. they cost me 300.00 us to make plus the drivers 190 each x 4. they are really strong.
Jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2005 at 2:48pm
I see you're selling them seperate from the drivers.  Why?
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2005 at 3:09pm
I will sell the drivers for 180 each.
I was going to use them for the next project, What ever that may be.
MixMan X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MixMan X Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2005 at 3:57pm
I reckon you would be looking at well over 500 for a pair, not including drivers, built out of birch ply to a professional finish.
Xmax extreme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xmax extreme Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2006 at 10:27am
Originally posted by angus angus wrote:
The other thing is, I'm sure you can split that Selenium cab up into two units - one driver in each - to make transportation alot easier. Stacking two together should give alomst identical output.
   Hi angus, need help with the selenium cab designs.  you've said that it can be split into two in order to have one 18's in a single cab.
   What would be the effect if the width will be increased? from the original plans the width is 100 cm, if split in two, 50 cm or 19.6 inches. What would be the effect concerning the quality of sound if i will increase the width to let say 23.6 inches or 60cm while the rest of the measurements remains the same.
   thanks for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xmax extreme Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2006 at 10:56pm
