  New Posts New Posts RSS Feed - help me design a cab for this
mashgwan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashgwan Quote  Post ReplyReply Direct Link To This Post Topic: help me design a cab for this
    Posted: 18 January 2006 at 12:17pm
its a series 1 x 15" rockford fosgate sub, heres the spec
http://www.rockfordfosgate.com/library/datasheets/s1-415_815 -ts.pdf
its currently in a sealed reflex box but i wanted to put it in a band pass or maybe horn so if any one has any sugestions , ive just bought a discovery so size isn't a problem
djdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djdan Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2006 at 1:12pm
i wud download winisd input all the data from ther and play about untill you get the best possible configuration
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashgwan Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2006 at 8:35am
ok ive had look at winisd , do people sugest i run either a 4th or 6th order bandpass
fidodido View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fidodido Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2006 at 6:37am
Hi,
I would't use this speaker at all. It is more suited for free-air application as it needs lots of Liters.
In Bassreflex 195.8 Liters is needed to go down to 35 Hz.
In bandpass the box will even be bigger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashgwan Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2006 at 7:55am
i already have this speaker lying around
bartsegers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bartsegers Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2006 at 2:50pm
forget all normal simuation situations, as the wofer is placed IN a car.
LOw freq. boost is huge, so no big enclosure is needed. (to get output under 80hz. (for example)
LunchieTey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LunchieTey Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2006 at 11:03pm
I would say 3cuft(about 85litres) sealed. The series 1(getting old now-prolly 10 years!) were most commonly used in large sealed. You want the roll-off to start around 70hz and be around 15-20db down at 20hz. This will give a relatively flat respons in a car. A 4th/6th order cab for a series 1 would be the size of a small fridge...
Speaker addict
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashgwan Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2006 at 8:52am
the thing is that it is in a sealed cab thats about 3cuft at the moment but i have a large boot in my new car so i thought it might make a change to stick it in a larger bandpass, do you think it would sound better in a 3ft reflex or a larger bandpass (as i have the space to fit a small fridge in the boot, and the cab will have speakon plugs wired in for quick removal
Edited by mashgwan - 06 March 2006 at 8:54am
