HELP! need info on a cab manufacturer |
Post Reply | Page 12> |
Youens.james91
Registered User Joined: 28 August 2015 Location: Leicester Status: Offline Points: 14 |
Posted: 28 August 2015 at 8:39pm |
Hi all,
I recently purchased a job lot of unloaded cabinets off of Ebay (6 15" dual band-pass subs and 4 15" 2 way monitors) The manufacturer on the back plate is TS2 which is based in Canada although i haven't seen any website or able to find any information on them etc as to what they are suited for driver wise. if anyone has any info as to what would could be used in them etc (PD, FANE, CELESTION ETC) that would be fantastic. i have a pic or two of the cabs them selves and wouldn't mind knowing what sort of application i can use them for as well. many kind regards to all James |
mini-mad
No picture.... try resizing to less then 1meg OR hosting it somewhere yourself. But either way your current picture isnt showing and its the one we need to help you lol
Youens.james91
still learning the tips and tricks of posting images, will try a different way 2 secs
Edited by Youens.james91 - 28 August 2015 at 8:57pm |
Youens.james91
mini-mad
Band pass subs.... boxes like that are designed to play JUST sub... and bloody loudly (well thats the idea anyway) a system like that would require kick bins.
Get your tape measure out and tell us the dims... a look at your driver and a look at the inside of one too. Give us as much info as you can!! |
Youens.james91
i can get you the dimensions and pics of the inside etc, i bought the cabs as a lot unloaded though which is where i may need abit of thinking as to whats best suited for them.
i will post the pics and dime's up soon cheers =]
Youens.james91
from with access panel off
internal bottom to top internal top to bottom, there is a gap behind the driver mount which is seperated and sealed Ext dimensions are ( H 655 mm x W 505 mm x D 620 mm ) tuning port dimension are ( cab 25 x 10 cm) and ( access panel 10 x 10 cm) |
ermita
Young Croc Joined: 19 August 2010 Location: Surrey, TW10 Status: Offline Points: 1266 |
Thanks(1)
http://www.12kw.de/Showservice/html/subwoofer.html
Tops should be the one from the same company under fullrange system. Edited by ermita - 28 August 2015 at 9:43pm |
Youens.james91
Legend thats the first website that has the cab on the homepage ive seen
kudos =]
mini-mad
Wow you stuck them up on facebook for sale fast!!! Lol
Youens.james91
i have a set of 6 with 4 of the tops, so have 2 spare subs, looking for 4 hd15s as kicks and some 18 inch bins/scoops to go on the bottom now haha plus blue aran dont do a 6x pack of drivers but they do 4x packs so makes sence in my head lool
matty w
Young Croc Joined: 27 August 2008 Status: Offline Points: 798 |
What would be an ideal low pass for the sub then ? Single 18" bandpass isn't it ? Typically ??
I would of thought the 4 reflex 15" tops would give you a fair amount of kick,depending which comp and 15 you use. That's the beauty of reflex tops ..... There wider frequency range. |
Black to black , red to red , blue to bits ....
