HELP needed: American 110 volt QSC PL3.4 |
Post Reply | Page <12 |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
No! You have to design one from the start for that to happen. The PL uses its capacitors as a voltage doubler for 120V use and in series for 240V by rearranging wire pcb links. The basic board is the same but there are also components different as I mentioned such as the filtering components different values and the soft start. It is not out of the question to modify it to 240V but it isn't a user-asjustable thing as the pcb has to come out to do it. The 120V versions usually have 120V-rated mains connectors as well, ie the hubbel nema twist lock. |
North Staffordshire |
