  New Posts New Posts RSS Feed - Help Needed (Vintage Build)
mellotone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mellotone Quote  Post ReplyReply Direct Link To This Post Topic: Help Needed (Vintage Build)
    Posted: 07 March 2017 at 7:15am
Hi ya,
Trying to determine my gear b/c looking to get a custom preamp built asap. Undecided about using 12s or 15s for mid-range duty, leaning towards the 12s at the moment.
Is delivering balance from 100Hz – 2kHz asking too much from a pair of 12s or 125s?
Also undecided on what Comp Driver to use for mid-tops.
Current set-up:
Drivers
(4) Fane Colossus Studio 18b = low (have 2, looking for another pair, 2 double bass reflex Fane 200L plan stacked to create old-style quad-box)
(2) Fane Colossus / Studio 12MB = mid (thinking Fane angled Mid/High cabinet, other suggestions???)
(2) Compression Horns JBL 2446h??? = mid-top (not sure here, willing to go modern driver Beyma / BMS / B&C here if sound is superior)
(4) Fane 5022 bullet tweeters = hi
Amps
Crest 8001 = Bass
RSD 800b Studiomaster = Mid Bass
Peavey CS400/800 = Mid-tops / Highs
Backup amps:
BGW 750B
Initial thoughts on x/o points for 3-way:
bass = / 100Hz
mids = 100Hz - 1.6kHz (seems a stretch)
mid-top = 1.6kHz - 6kHz + hi = 6kHz /
Also looking for thoughts on running this set-up 4-way (based on proposed or other recommended drivers): would be nice to go 4-way and still have the option to run 3 when needed.
Anything you'd do differently?
Type of Sound:
Size: Small-ish Medium sound for playing small pubs, community centers, outdoor, private parties, etc.
Sound: "Of the era," inspired vintage reggae sound (rocksteady/roots/dancehall/mid 80s digi) using components from the 70s - 80s (and modern pieces where more practical) with emphasis on quality. Less concerned about blistering volume and more concerned with quality, fullness of sound.
Appreciate any and all feedback.
Edited by mellotone - 02 April 2017 at 7:04pm
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 07 March 2017 at 8:46am
Vintage I'd say lose the mid Fanes and compression's and use dual (whizzer) mid cones straight to bullets.
Real world today, nearly spot on but bring compression's down to 2k or so
100hz is spot on for the 200l Fane box, done it lots.
Careful with 8001 on four Studio B's. Triple good luck finding more, stunning driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mellotone Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2017 at 12:27am
Thanks Nicky,
Appreciate the whizzer reco, will give it some thought.
Any particular one in mind?
What's the watch-out on the 8001?
Edited by mellotone - 08 March 2017 at 1:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 08 March 2017 at 8:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mellotone Quote  Post ReplyReply Direct Link To This Post Posted: 09 March 2017 at 8:17pm
Thanks for the link, I'll take a stroll through that thread—looks a good discussion.
Still debating how to handle the mid-range spectrum, either going with:
18s
12s
1" or 1.5" comp driver
bullet tweets (Fane 5022)
crossing at —100Hz bass / 100Hz — 2kHz mids / 2kHz — 6kHz / 6kHz — tops
vs.
18s
15s
2" comp driver
crossing at —100Hz bass / 100Hz — 900Hz mids / 900Hz — 6kHz comps, not sure here??? / 6kHz —
On the 8001:
those Fane Col 18s are rated at 400w each which = @1600w total for the quad-box so I was planning on running the 8001 at 4ohm, (which gives @ 1200w per channel = 2400w total).
Edited by mellotone - 24 April 2017 at 4:26am
